Question about Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
  • 2 more comments
  • rl52302 Dec 12, 2008
    i need the codes for a philips magnavos remote control for a sanyo tv.
  • ckay7 Dec 28, 2008
    need code for 13'' PHILIP MAG. SMART LOCK
  • Anonymous Mar 23, 2009
    i need to user guide for a philips magnovox universal remote model rem110 nz does anyone know where i can obtain this information
  • Anonymous Apr 08, 2009
    I have a Philips universal remote. I need the codes for a Daewoo T.V.
    Novelist:
  • 97 Answers
Http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
Need a code for tv akai
Posted on Jan 25, 2009
I have a magnavox tv and a GE remote that I can't get to work
Posted on Dec 16, 2008
I need to get the code for a philips magnavox remote control for rem 110
Posted on Dec 12, 2008
4 Suggested Answers
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
Posted on Feb 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal remote codes for symphonics tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Hope this helps :)
Posted on Jun 18, 2008
Need a code list for a philips uuiversal remote us2 435 sl
We lost the code list sheet to our Philips Remote Control US2-PM4S Universal Big button remote and we need the code for a ilo tv.
Jan 26, 2010 | Philips Televison & Video
Need code for remote
Here is the link to the instruction manual which should help you find the code.
Hope that helps!
Mar 25, 2009 | Philips Magnavox Learning Universal Remote
CODE FOR PHILIPS UNIVERSAL REMOTE
I ALSO NEED THE CODE TO SET UP MY TV CAUSE I LOST THE CODE SHEET
Nov 22, 2008 | Philips Universal PH301S Remote Control
Need codes for PM435S
i need a code for phillip universal remote sharp # urc8820
Aug 10, 2008 | Philips Universal PH301S Remote Control
TV Remote
Go to thsi site and all codes are there.
http://www.universal-remote.net/philipsmagnavox.html
the code for the sanyo tv is one of these
002 412 506 619 902
Mar 11, 2008 | Philips Universal PH301S Remote Control
Help
I have a philips universal control and I need the code for a memorex tv
Feb 14, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote codes for symphonics tv
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
Aug 22, 2007 | Philips PM3S Remote Control
Philips Magnavox Learning Universal Remote Logo
894 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
