Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My side by side fridge, fridge side is feezing up...
Hi, i just have a question about my side by side fridge, it just happened recently that my fridge side is freezing up. I cleaned the whole fridge even the coil underneath by the compressor and the problem still do exist, any suggestion on what do i have to do?
  • Saso74 Jun 22, 2008
    I am currently having the same Issue with my 2 sided Kenmore refrigerator, where the freezer side freezes and when the refrigerator cools down because the freezer side freezes over. So I do the following to correct the issue until it freezes up aging. I get a blow dryer and blows dry the freezer side and then it starts to work aging. I would like to correct this issue once and for all.
    Thanks
    Mitch
    saso@tmo.blackberry.net
  • legaspi Jul 22, 2008
    Thank you sir, sorry for not responding right away but my fridge is now working, just like what you said i tried to reset the timer and it is just a timer problem and now i have the fridge work like a champ... again, thank you...
    Genius:
  • 1,122 Answers
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Posted on Jun 21, 2008
I have a defy frost free fridge, why is it not feezing on the freezer side
what is the temp dial in the refrigerator set to if too low that will cause the problem and having low freon will also cause it . if flow on that gas only a service tech can fix legally
Mar 10, 2015 | Frost Refrigerators
I have a kitchen aid superba side by side black with ice maker and water dispenser. Questain is I have it outside plugged in, during the day sun is on it, will this affected the feezer side from keeping...
yes, the insulation in the fridge is not designed to handle that kind of heat, and it being black only compounds the problem. eventually the refridgerator will overheat and fail. it doesnt need to be in the a/c, but it does need to be out of the sun
Sep 26, 2013 | KitchenAid Kitchen Aid Superba Series...
Refridgerator side feezes uo
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 26, 2011 | Refrigerators
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
FREEZING REFRIGERATOR
Hello Pam, Welcome to FixYa. In actuallity most fridges whether they are side by side, conventional top mount, or bottom mount, the control for the fridge section is nothing more than a damper which allows or prevents air flow through the fridge section. The thermostat which control the "run time" or actual temperature is the freezer control. It is possible to set the fridge control at "1" and yet still have items feeze because the freezer control is set to "3", "5", or higher. Try adjusting the freezer control to a lower number as well and see what that yields. You may also want to vacuum out your condensor coils under the unit...( unplugging the power cord first of course ;) safety first ) this too can cause items to freeze in the fridge section. Without getting too deep into how it all works I'll just say it effects the entire system negatively. Hope you find this an acceptable solution and can take a moment to rate it accordingly. Thank you for visiting FixYa and please let me know if you require further assistance. macmarkus :)
Jul 12, 2010 | GE GSS20IEP Side by Side Refrigerator
Vegetables kept out of the crisper drawer feeze up why does this happen even the temperature control is set below 1 on the dial
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2009 | Refrigerators
The ice maker doesn't work. I can get cold water from the refrigerator so I assume that the line is not frozen. I just changed the water filter to see if that might help but it didn't.
Check the folllowing:
The end of the ice chute inside the freezer compartment that dumps into the ice tray - they can feeze and block water flow.
Remove the water chute and see if the water orifice is frozen. If so, it will block water flow. it can be thawed out with a hair dryer (carefully).
If no luck, look for a bad water valve or possible kink in the water line. This valve is usually located under the back of the fridge behind a cover.
If all ok, there could be an issue with the ice maker itself or on some units, a control circuit board.
Try unplugging the fridge, let it sit for at least 5 minutes and then plug it back in and see what happens.
Apr 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
FRIDGE DOES NOT COOL
Hi, Have you recently defrosted the fridge? with any type of sharp object?? If so you could have put a small hole in the evaporator plate which has caused the gas to leak out! Or if you have not then depending on its age there could be a small hole appeared outside the fridge in the condenser on the back and the gas has leaked. Or which does happen is the compressor has gone weak and will not pump the gas round the fridge hard enough to condense it and therefore it does not get cold..
If you can give me anymore information then i could tell you exactly the problem.
How long does the compressor run for and is it hot??
Jan 02, 2009 | Frigidaire FRS26R4A Side by Side...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Iced up pipe in back of ge side by side refridgerator
Hi there, yes this will happen when the fridge has been over charged with refrigerant. :) If fridge under warranty get them to come and have a look :)
Sep 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
