Question about Car Audio & Video
Eurovox 8790FR stereo out of 1998 landrover freelander need code please
SOURCE: 2002 Landrover Freelander Code P1472
code P1472
Posted on Apr 26, 2009
  • 136 Answers
SOURCE: i need some fitting instructions for a rear window
as simple as i can put it here goes , you will need to remove rear door panel using a flat blade tool, start at top and work your way round to hinge side,peel back the weather sheild about six inches down all along the top edge , this will reveal the mounting points on the back of the rear panel, leave the removable ends attached to the window guard and line up against rear panel, check which hole's need to be used and attach brackets to these points using bolts supplied in kit or what ever you have to hand. once mounted you can pull guard from brackets and put to one side , next is the rear panel if you place panel face down revealing back it will show two ovalish shape's highlighted by faint outline , this is where you will need to cut and file . when that is finished you can reinstall rear panel on to door, install rear guard and locking bolts. it always handy to have spare clips for door panels as the become brittle with age.
Posted on Sep 04, 2009
Testimonial: "Brilliant - thank you...."
  • 1147 Answers
SOURCE: Low Fuel Pressure on Landrover Freelander TD4
causes .bad filter,gas line leak,tank leak call dealer to find aux pump.bad gas.i had a truck i replaced the in tank fuelpump 5 times one week they were all bad. could be as simple as your gas cap? any check engine lights on?
Posted on Oct 07, 2009
  • 12 Answers
SOURCE: anyone have the codes for eurovox 5a01 oct 09 please?
New Code For TW and Virgin Please CHECK PROpely and Try ,,,Good Luck
5A 01
00/83 5d 12 b8 96 f6 1f c4
01/D2 F9 3F 22 0C A7 D6 C9
Posted on Oct 08, 2009
  • 1986 Answers
SOURCE: i have a 1998 landrover freelander how do i adjust
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Posted on Nov 04, 2009
How can i find a security code of 2000 land rover freelander for audio system?
How can i disable the security code of 2000 landrover freelander
Dec 09, 2010 | 2002 Land Rover Freelander
I have landrover(free lander 2003 model), my car is asking code in stereo, so can you please help me out from this problem.
Check in your service / owners manual to see if the code is recorded, if it is then follow the procedure for entering the code from the manual. If you dont have the code then you need to go to the dealer to check and get the code for you. Codes will not be given out over the phone , because it may be a stolen stereo, so take your ID and registration document with you.
Hope that helps
Mar 26, 2010 | 2003 Land Rover Freelander
Landrover Freelander V6 engine code 25K, Need Cambelt timing marks
i want to know the timing marks for my 2003 land rover freelander
Aug 19, 2009 | 2003 Land Rover Freelander
Need instruction book for Landrover Freelander 1998 xei where do i get one?
Have a look on ebay in car parts landrover section and click onto freelander there is sometimes the cd workshop manual under rave, which is excellant and full of info
Jun 03, 2009 | 2002 Land Rover Freelander
Landrover freelander 1998
Too complicated to advise, to set up a diff you need to be experienced. Either get a skilled engineer to set the diff correctly, or change the full axle from another vehicle. If you dont set the diff correctly, it will whine and prematurely fail.
Dec 31, 2008 | 2004 Land Rover FreeLander
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
