TRYING TO SETUP CHILI DVD 8500X AND IT KEEPS SAYING INPUT TUNER NO SIGNAL WHAT IS THIS
My Haier tv says "No Signal" & won't show my channel I did auto scan & it's still blue with a grey box saying "No Signal"
To eliminate if it's the cable problem or not, see if you're able to get a picture and audio on another input by connecting a dvd player as an example. If you're able to receive a picture and audio tehn you know that input works. If you can then try connecting a antenna to the tunner, assumming that you had cable connected prior, and scan the channels again but instead of selecting cable select air then channel scan. If you still are not able to receive channels, then you have a bad tuner. You will need to have the main assembly board AKA scaler board replaced. You could however by-pass the tuner by using a VCR and connect your cable to the tuner on the VCR then use Composite wires from the VCR to the TV composite input and change the chanels from the VCR.
Oct 23, 2013 | Televison & Video
No signal
What model is the TV? Are you using a HDMI input or is it a standard CO-AX Antennee cable?
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
My element electronics tv says no signal
Two things to try:
1. Connect a DVD or something else to one of the rear audio/video inputs to see if set works that way.
2. Check to make sure set in menu is set to tuner and cable---if the tuner in the set is bad a cable box with audio/video outs on the back can be hooked to one of the rear audio/video inputs and will bypass the tv tuner--you will stay that input to watch TV and change channels with the box----
The cost of renting a box is minor compared to having to replace the tuner in the set.
Mar 24, 2012 | Element Electronics Televison & Video
Hi there, I'm trying to play a VSH/DVD through my
This happens when the computer signal is being used as the input, and the signal disappears or is the wrong type.
It may have tried switching inputs if you were using the video input rather than the pc input.
Press the auto image button to get it to select the correct input.
If you are using the PC as the dvd player, then change the display settings ie computer screen refresh rate, and resolution to suit the projector
Apr 06, 2011 | InFocus IN26 Multimedia Projector
Was trying to install new dvd and now have lost tv signal by trying to get proper setup for dvd. Did not get dvd to work and now tv screen lists no signal tried several times to reset tv but cannot.
Buy and replaced it with a new HDMI cable to the DVD player for better function.Tries unplug the tv about an hour,replug it back in.Goto tv menu,goto PICTURE.Go down to reset the Tuner board back to Facrory setting.The tv should have signal now.Not than the tv Tuner board have problems,must be change,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 16, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a Polaroid tv. My cable company came out today and updated me w/ digital tv and dvr. Things were fine when the tech was here and afterwards I watched a dvd and when I switched the input back to the...
Check the back of your TV. Your cable is probably hooked into a Composite or HDMI input, I doubt they would install it directly to the TV's tuner, these days thats reserved for local antenna's.
Jan 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Copy TV to DVD/R
sao ha sao ha sao ha sao con cac
sadfassa
sdadas
dasds
adsa
ds
dsa
das
das
dasd
asdas
das
das
Apr 11, 2008 | RCA DRC8335
Channel Setup
it's saying that because the antenna is hooked into the same thing, the coaxle jack. It shouldn't memorize any chanells that don't come in on the antenna. It's been a long time since I had mine hooked to an antenna but I know it'll work if you let it go through the auto setup. If need be unplug the unit for like two minutes so it's memory is erased and then fo form there. I hope this helps
Jan 02, 2008 | Emerson EWD2202 DVD Player/VCR
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
