Question about Creative Labs ZEN Vision:M Digital Media Player
Vision m plugged in 2 computer blue lite blink on and off. charges all day. unplug, turn on, lite blinks 5 times and nothing. won't turn. replaced battery. still nothing. WIN XP w. SP2. Acts dead.
  • 3 Answers
Here, this is what I did to fix this problem. copy and paste from my original post on anythingbutipod.com
"My player is completely charged, I have XP w/SP2 - I can turn it on and listen to the default audio tracks and videos...I just can't get my computer to recognize it AT ALL!"
and then:
also, when I try to allow "everyone" to the USB....I found that in the advanced section I have TWO "everyones".
The one that says "full control" says "not inherited" in the inherited from column...the other says "read" and "machine\system\currentcontrolset......."
Should there be two of them in there??? Because when I try and switch the read to full control, it reverts back as soon as I select apply or ok....I tried deleting it but it re-creates itself soon as I go out of the window.
so I was told to do this:
Sounds like an NT problem. I don't know the exact steps to do this, but you'll need to remove inheritable permissions from that, which will remove the "inherited" attribute, leaving the locally-controllable one.
So open "run" command in the start menu and type "regedit"
From there follow this path...
"hkey_current_config" -> system -> current control set -> Enum -> USB
Do what I copy and pasted above and then plug your Zen V:M in and it should recognize it.
Posted on Jun 21, 2008
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Hi, my ZEN vision m: does not start anymore; when charging the blue light just "flickers", but even after 1 night charging, no possibility to get to the menu
The rapid-blinking blue light means that the Zen's battery is too drained to allow the player to turn on.
It can take 24 hours or more to completely recharge the Zen using USB. If you see the blue light blinking slowly when you plug it in, then the player is charging, and you will have to wait for it to finish charging.
If, after leaving the Zen to charge for more than a day, it still does not turn on, then the battery may be defective and not able to be charged anymore. The battery will have to be replaced.
May 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
Power lite started blinking, i unplugged and waited a bit and plugged back in. Now no lite at all, nothing. Is it dead?
check the cable or replace it if you do that and start blinking clean the memory module by pencil eraser
Jan 02, 2010 | LG L194WT 19" LCD Monitor
CREATIVE ZEN GONE HAYWIRE
sounds like it might be either a bad firmware driver, which can be erased and reinstalled via the USB connection to your computer and a download from creative. Or the battery has gone bad, in which case you have to have it sent to creative for Repair.
Jun 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M won't charge
This could be a hardware issue, but try this:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 10, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
60 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
