Question about LaCie (300740) 160 GB Hard Drive
Power supply problems
I'm replacing a power supply in a three year old desktop. I've hooked up the cables properly, but my hard drive will not kick in. any tips?
  • 38 Answers
Have a look that all the cables are in proppaly what it probably is the power cables are inserted in the rigth orded lastley could the hdd be set at slave and not master
Posted on Jun 21, 2008
Seagate external hard drive won't turn on. No lights, not power cable not power base.
Try new USB cable. Still no joy, data recovery is very expensive. Last ditch efforts (not all at once), try putting it in the freezer, twist the drive opposite corners, give the drive a firm bang
May 13, 2014 | Seagate FreeAgent Pro Desktop - 320GB -...
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Disk boot failure.insert system disk. Message that appear a boot up
first of all check in your BIOS whether your motherboard is detecting your hard drive or not.
If yes try installing window.
If not it means your hard drive is not detected , Open the case and check hard drive data cable is connected properly or not, and hard drive is getting proper power supply.
you can try changing hard drive data cable and power connector from.
If still you are facing the same problem that means your hard drive gone bad.
Jun 15, 2011 | Sony VAIO PCV-MXS10 PC Desktop
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I had a issues with my power supply no after i
Check to make sure that everything is properly hooked up again. You hard drive may have power flowing too it, but it may not be hooked up to the motherboard and reading properly. Just check to see if everything is properly hooked into the right spots. If it is, make a comment on this letting us know and I'll see if I can figure it out from there.
I hope this helps.
Oct 14, 2009 | Dell XPS 700 PC Desktop
Gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
Jun 23, 2009 | Gateway 500GR PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
I dont understand how to hook up my old hardrive to the sabrent hardrive enclosure
Open the enclosure, plug the IDE cable into the back of the hard drive. Plug the power connector into the back of the hard drive. Mount the hard drive with the included fasteners. Close the enclosure, Plug in the power supply to the wall. Turn on the external drive. Plug in the USB cable to your computer. Browse your files.
Apr 26, 2009 | Computers & Internet
Emachine t2984 - need to diagram to install power & hard drive
There is 2 main cables you have to worry about to feed power to the system. One looks like a big rectangle block with a mess of wires attached. Make sure he is hooked into the system. Then if its an newer unit you will find a plug that has square look to it with just 4 wires attached and should plug in nearby the processor. (only newer units us this) Also if your dealing with the cant turn it on issue make sure to remove all cards off the board like the NIC, Video Card, and Audio Card. I am unsure as to weather or not your system comes with everything onboard or if its stand alone cards. If you still cant power on theres a bigger issue at hand and that maybe that your motherboard has blown.
Mar 16, 2009 | E-Machines eMachines Desktop PC
Ide issues
create partiion and format hard drive.
Mar 06, 2008 | Compaq Presario 5000 PC Desktop
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
52 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
