Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
How to replace ballast in toshiba 52hm84 dlp rear tv.
Dear Sir, plz provide link or web for Toshiba 52hm84 dlp tv . i need to replace ballast . just changed new lamp tv still don't work yet. light blinks 8 times and goes off. after replce bulb we saw over 2 hrs tv and it just dead. after read some tips on this web, we saw your help info.
plz answer back to us asap...dpatel65@yahoo.com.
  • 1 more comment
  • TeFang Jul 04, 2008
    My TV had the same problem! Some people said 'Light engine' might had problem. What's that?
  • drjonkk Aug 22, 2008
    How can I remove the old ballast on this Toshiba and replace it?  No instructions are with the TV manual.  I have tried for hours to get into the section that houses the ballast.  Changing the lamp was easy.
  • woodsm723 Mar 23, 2009
    I think I have a similar problem. I've had my Toshiba 52HM84 for 40+ months and I'm still on the original lightbulb & ballast. Tonight, the tv just shut off (out of nowhere) and the start-up lights starting going from green-to-red and the tv started starting up and shutting off, however with no picture. Has the bulb gone bad? Or has the ballast gone bad? Do I order both parts? Any assistance would be appreciated.
How do I change the lamp?
Posted on May 15, 2009
52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Jan 18, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
Toshiba 52HM84 Manual Download
Toshiba 52HM84 DLP Projection HDTV Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV instructions.
I hope that helps.
_______________________________________________
Toshiba 52HM84 Service Manual Download
on May 14, 2010 | Televison & Video
Tip
Toshiba 52HM84 DLP Projection HDTV Service Manual Download
Have you misplaced your Toshiba 52HM84 DLP Projection HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 52HM84 DLP Projection HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 52HM84 DLP Projection HDTV Service instructions.
I hope that helps.
on May 13, 2010 | Televison & Video
Do I need to remove the rear cover on a 52HM84 Toshiba TV to change the ballast unit?
Click here to download the service manual. The rear cover will need to be remove to gain access to the ballast.
Jan 05, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
on May 13, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
I hope that helps.
Toshiba 52hm84
Search "Ballast replacement for Toshiba 52HM84" on your favorite web serach engine
Oct 25, 2008 | Televison & Video
I have a 52" Toshiba
the ballast isnt keeping the bulb lit.
Mar 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
2,826 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
