Question about Toshiba Satellite A105-S4004 Notebook
My wireless network is no longer listed
I can't connect to my wireless router anymore. I tried refreshing the list of available networks, but that didn't work. I tried rebooting the router and the modem and refereshing list again. Nothing works. It's been fine for years. I don't know what happened to it. The router shows a blinking light for "WAN", a solid light for "ACT" and no light for "link".
  • 2 more comments
  • paisley11 Jun 21, 2008
    Toshiba WRC 1000
  • paisley11 Jun 23, 2008
    Thanks for your assistance, but I got it working. I ended up turning off the wireless router and hooking up direct to the modem for 24 hours. Then just for the hell of it, I decided to try the wireless again. It worked!! The "link" light is now blinking!!! Maybe the router needed some rest. Thanks for your quick responses. I love this website!
  • aemam_85 Mar 17, 2009
    wirless not working
  • Simon Vann
    Simon Vann May 11, 2010
    Can you please clarify the make and model of the router.
  • 85 Answers
Ok there needs to be a few diagnostics first.
Can you still connect to to router with a wired connection?
If so, can you veiw the settings for the wirless network,, and are they the same as before?
If you cant connect with a wired connection i'd probably say the router needs replacing.
Please let me know if you can connect with a wire and if you can access the wireless settings?
Posted on Jun 21, 2008
My wireless network connection disconnected. When I tried to reconnect (I have a secure wireless router connection), my network name wasn't listed in the list of options. I restarted my router and...
1. Directly connect to the router with an ethernet cable from your PC.
2. On the browser, enter the router's IP address
3. Log into the router
4. Navigate to router's wireless setup
5. Change the SSID to something NEW and DISTINCTIVE - do not use a default SSID
6. Make sure SSID is being broadcast - click to set the check-box if it wasn't set before
7. Save and exit the router setup then disconnect the ethernet cable
8. On your PC, View Wireless Network Connections
9. Click Network Task to Refresh network list
10. Your router with new SSID should show on the refreshed network list
11. High light your router's new SSID and click the Connect button
12. On the pop-up requesting WEP or WPA key, enter the key you had set in the router before.
Mar 30, 2011 | Toshiba Satellite L305-S5907 Laptop
Hello my wireless laptop does not connect to my wireless network it says "Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of...
make sure that the signal strength in that area is good...
normally this happens when the network range is very low... probably u will have to try connecting having the router kept more nearer..
Mar 17, 2011 | Computers & Internet
Net book will not connect to internet through WiFi. With cable is ok
Here are some suggestions that may resolve your problem....
1. if another computer is connecting OK through WiFi, then the problem is likely with the N150
2. if nothing else is connected through WiFi, then you need to check both N150 and router
3. on N150 without cable, click start and click Control Panel then double click Network Connections
4. Network Connections should show Wireless Network Connection and Local Area Connection
5. if Wireless Network is missing, click back and double-click Wireless Network Setup Wizard
6. if wizard done but Wireless Network Connection is Not connected in Network Connections window
7. in Network Tasks in left sidebar of Network Connections, click View available wireless networks
8. in Wireless Network Connection window, click on Refresh network list in Network Tasks sidebar
9. if No wireless networks were found.... then Make sure the wireless switch on N150 is on
10. with the N150 wireless adapter now enabled, click on Refresh network list
11. if SSID for your router's wireless is listed but not high-lighted, click on it to select the SSID
12. click the connect button, if security-enabled wireless network, a pop-up appears for key input
13. click the connect button after entering and confirming key inputs
14. if after step 10 the SSID for your router is NOT listed, you will need to log into the router
15. connect the N150 to the router using the ethernet cable then open Internet Explorer
16. in IE's address field, type the router's IP address - it is in the form of 192.168.x.x
17. if it is not known, open Network Connections window (step 3) and right-click Local Area Connection
18. in the pop-up, click on status
19. in the Local Area Connection Status window, click on the Support tab
20. the Default Gateway has the router's IP address
21. after entry of IP address, IE presents a router login window for userid and password entry
22. unless changed, the router userid and password defaults are given in the router's manual
23. on the first router screen (usually Setup), click on the Wireless tab
24. if Wireless Network Mode is Disabled, click on v for pull-down then click on appropriate mode
25. if SSID is blank, enter a Wireless Network Name then click Wireless SSID Broadcast enable
26. click Save Settings then click on Wireless Security tab in the Wireless window to set WEP/WPA
27. see your router's manual for details on how to setup WEP or WPA mode and its key
28. if you don't want wireless security (OPEN), then set Security Mode to Disabled (default)
29. if any changes, click on Save Settings then click on x at top right corner of IE to close it
30. disconnect the ethernet cable and right-click the Toolbar's Wireless Network Connection icon
31. if the icon (a single screen with ))) beside it) has a little red x, then on the pop-up...
32. click View Available Wireless Networks then in Network Tasks sidebar click Refresh Network List
33. continue with connecting to the wireless network at step 11....
Feb 21, 2011 | Samsung N150 (36725723009) Netbook
I have a wireless connection but cannot open the browser. Another computer (laptop) is connecting fine on the same wireless.
If the Wireless Network Connection icon is at the bottom right of your Taskbar and has a red x, then right-click on the icon to bring up a pop-up window and in that window, left-click on View Available Wireless Networks. This will open a Wireless Network Connection window which will allow you to Choose a wireless network. If the window has the message "No wireless networks were found in range", then you will need to slide the spring-loaded switch at the right-front the netbook to the right momentarily and the message "Wireless LAN Enabled" should show in large green letters at the bottom of the screen. Then in the Wireless Network Connection window, left-click on "Refresh network list" item under Network Tasks. In about 10 seconds, a list of the wireless networks will be displayed which should include the name of your wireless access point (wireless router). Left-clicking on that list item will high-light it in blue. Now click on the connect button at the bottom-right of the window. If the list item has a lock symbol, a Wireless Network Connection pop-up will now show to ask you to "Type the key" otherwise for an unsecured or open access point, a connection should automatically occur without having to type any key. The Wireless Network Connection icon in the Taskbar should no longer have the red x and hovering the mouse cursor over it will show the Wireless Network Connection status. Hopefully, if this procedure has solved your problem, you should consider securing your access point to prevent unauthorized access of it. After securing, you will need to refresh the network list and then do a re-connect.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
Laptop no longer recognizes wireless network
Have you tried unplugging the router, and replugging it?
Sometimes the password is in [ ] right on the router near the serial number.
Some routers have a reset button you may have to push in with a toothpick.
Jul 03, 2009 | Belkin Computers & Internet
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
"unable to connect to selected network" error
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
205 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
