Question about LG Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
  • LG Master
  • 8,617 Answers
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) To Check if it was a success
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Posted on Jun 21, 2008
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
PT-61LCX65 lamp light flashing. Believe I need to change lamp and reset? Could you tell me how to reset?
Check the owner's manual to be sure. The troubleshooting section should list the meaning of the flashing lights. Typically this is a bad lamp indicator or a lamp life indicator. The replacemetn lamp should include the instructions for replacing the lamp and resetting the lamp life counter.
Dan
Nov 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
How do I reset the lamp life on my LG 52SZ8R.
hold the mute on the remote and press enter on the tv and it will come up in the menu for you to reset
Jul 08, 2009 | Televison & Video
How to reset the lamp timer count on a LG rear projection TV
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
Jun 15, 2009 | LG Televison & Video
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Lamp indicator
look in the customer menus for lamp hours reset
Sep 05, 2008 | LG RU-52SZ51D 52" Rear Projection...
Lamp Indicator is Orange
Press 'Enter' on the TV then press 'Mute' on the remote while holding 'Enter' down. A menu will pop up on the screen, allowing you to reset the light. It's also worth noting that you can get to the service menu by pressing 'Menu' on the remote and TV at the same time. There is an option for checking the number of hours on the lamp.
Apr 19, 2007 | Zenith E44W46LCD 44" Rear Projection...
Resetting the indicator light
Hold down on the Enter or OK on the TV and Mute on the remote control for 5-10 seconds. The TV should then ask what you want to do. Perform this with the TV on.
Jan 31, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
494 people viewed this question
