Question about Hanns.G Corporation HW191D 19" LCD Monitor
Cannot remove "input signal out of range"
When playing a game, there is a box in the middle of the screen that will not go away and it says "input signal out of range". I have tried to go to the menu and change the input settings - it will not change from "analog". Is that the setting it is supposed to be on all the time? How can I remove this annoying box?
  • whyknotlf11 Dec 12, 2008
    I have a smaller screen, Hanns-g HW173D, with exactly the same issue. It is OK for a while and then the box appears and we have to shut off the computer to get it to go a way.
  • 85 Answers
Input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Posted on Jun 21, 2008
  • fieldsm0107 Nov 23, 2010
    Mine was caused by too high of a refresh rate. Control Panel>Appearance and Themes>Display>Settings>Advanced>Monitor and adjust the screen refresh rate to a lower setting.
If using windows 7 try a right click on the desktop, then screen resolution and then detect. That worked for me.
Posted on Feb 01, 2011
My Nintendo 64 when I was in the middle of a game it froze and the screen went all black and then it went to the tv screen saying no signal then.
Well one time I had this problem with my Nintendo 64 console when I was in the middle of playing perfect dark the screen had froze went black and then it went to saying no signal on the tv screen. The console did not over heat to cause this problem. I thought that it had died on me but I had tried a new expansion pack and it was fine after that. SOmetimes the expansion packs can blank out in the middle of a game play they can die without a warning then. Or it can say expansion pack needed or it will give the white flash that it is turning on but nothing happens after that then.
Mar 22, 2016 | Nintendo 64 Console
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
No video signal comes on screen when watching movies and playing games in video 1 signal
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Toshiba Televison & Video
Floating gray box that says input not supported
When do you see the grey box? When you are playing a game? If so, try changing the resolution on your screen through the Control Panel...personalization...the resolution scale. You may need a lower resolution in order for the game to be played. I used to get a box that said "signal out of range". It wouldn't go away until I lowered the resolution in order to play that particular game. You can always change it back to your original resolution. Did you have a message in the grey box.
Mar 20, 2012 | E-Machines eMachines Desktop PC
The hand on the screen from the wii remote jumps all over the screen.
There are a few reasons that this would happen.
1) Make sure that you are not to far away from the sensor bar, this can lead to a week signal for the pointer!
2) Make sure that you are within the range of the sensor bar, and by this I don't mean close to the sensor bar, I mean the angle you are opposed to the sensor bar. If you are to far of an angle to the left or right of the bar, it will have a tough time reading the signal input from the Wii remote. Best to stay as close to center while you are playing as possible.
3) Double check the battery level in the remote, which you can do by pressing the "home" button. If the batteries are to week, they will not send a good signal to the sensor bar!
Hope this helps! :)
Sep 14, 2011 | Nintendo Wii Console
"Input signal out of range"
usually points to the resolution settings of the graphics card not matching the monitor resolution settings. Reboot to safe mode on the computer and set the resolution to a lower one. A good starting point would be 1280 x 960 at high res. See if that works
Jul 09, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
I have a Hannspree 25 lcd monitor and I can't get rid of the "input signal out of range" box in the middle of the screen
the monitor is not properly connected to the back of the PC box, check the cable that goes from the monitor to the PC box, (first unplug the PC/monitors from the power socket)
check if the cable is loose from the monitor jack point on the back of the PC box, remove it and blow air in it may be some dust is there.
fix it back and tighten the two screwes with a screw driver.
power it back ON
Dec 07, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
Jun 28, 2007 | Acer AL1916W 19" LCD Monitor
Hanns.G Corporation HW191D 19" LCD Monitor Logo
2,506 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
Matthew Spark
Matthew Spark
 Grubhead
Grubhead
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
