Ineedthe software for my philips snu6500 wireless adapter. It's gone walkies off my pc and the disc is at home and I'm not !
  • 611 Answers
I lost the software disc to my ZyAir G-200 wireless Network Adapter
You can find the software as well as digital copies of the user manual and anything else included with the adapter at: http://www.zyxel.com/osearch/dl-search.aspx?mci_country=us&mci_lang=en&product_status=all&product=G-200&mtype=ALL&keyword=&submit=Submit
Most wireless adapter companies (and most companies that make things that require drivers to be installed for that matter) have repositories of all the software and manuals free to download on their site for just these occasions. They sometimes take a few minutes to hunt down, but I've lost CDs or papers many times and this tip saved my bacon in a pinch. Hope this helps!
Oct 18, 2012 | Zyxel G-200 802.11g/b Wireless Adapter
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I have a SGB900 cable wireless modem. I have succesfully set up connection to the internet and laptop home wifi connectivity but can't set up my desktop to work with wifi netgear usb adapter. I am getting...
You should have a disc with the netgear adapter.First uninstall it then reinstall it.You could have a corrupted driver.Unplug the adapter from the pc and then reconnect it.
Aug 07, 2010 | Arris SURFboard SBG900 802.11g/b...
Belkin F5D700 installation software disc
u'll have all the drivers for this adapter in this link. download the correct drivers depending on the version of the adapter which can be found on the adapter itself. http://en-us-support.belkin.com/app/answers/detail/a_id/303/kw/f5d7000/r_id/166
Jan 18, 2010 | Belkin 802.11g Wireless Desktop Network...
I need the software for the netopia 3d reach wireless usb card
go to http://www.swisscom-mobile.ch/scm/kd_dsl_geraetesoftware-en.aspx at the bottom you will find the drivers for Vista
Mar 03, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Mar 13, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Help needed with WG834g & usb adapter
Sometimes a hard wire cable whether lan or usb is needed to set up the router first before going wireless. If not it maybe your pc needs a ip/dns flush from the last allocated numbers from your bt router. To clear this:- Click Start>Run, then type ipconfig /flushdns then press enter.
Jan 21, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
