Question about Maytag Washing Machines
What is e3 error on maytag front loader, i have no manual with washer.
Why e3 fault message in samsung front loading machine
Posted on Sep 21, 2009
  • 246 Answers
I can't remember that code off the top of my head, but on maytag, they include a tech sheet inside all of them. If your's has a console (controls are above the console) remove the 3 phillips screws and it will be in there. If your's doesn't have a console, then it's typically will either be under the top lid on the right hand side (remove 2-3 screws on the rear of the lid and slide it towards the rear and lift off) or finnally the 3rd place is if your unit has 2 panels on the front. The lower panel will have 2 #20 torx screws at the bottom. Remove these and on the inside of the panel you will see it. Those are the three places maytag (or the company that made them with a maytag name) puts them. The tech shheets will not only have a list of error code, but step by step instructions of entering diagnostic modes and tests to run to determine where your problem is.
Posted on Jun 21, 2008
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
My Maytag front loader washer gives an F H reading. Purchased in 2009, cannot locate owner's manual.
In the rear of the console inside is the diagnostic test sheets. They should tell you what error code means.
Jan 20, 2013 | Maytag Neptune MAH7500WH Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
E3 and be error on maytag washer
E3 error code is indicating that the motor should be running but the hall sensor for the motor is not sensing the turning of the motor.
Note - You could disconnect the power supply for few minutes, say 15 minutes and see if that resets the control board and solve the problem unless follow what was mentioned above.
For replacement instructions you can download this repair manual for your front load and follow the steps given in the manual and here the search parts.
Hope helps.
May 17, 2011 | Maytag MAH9700AWM Neptune Front Load...
Hello, i have a maytag front loader washer . it keeps giving me an error message of E3. What does it mean?
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board.
Apr 21, 2011 | Maytag Washing Machines
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
326 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
