Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero 630 hot door jamb
Hi, my subzero door jambs are nextremely hot. The seals seam ok, but the jambs are heating up as if there is some kind of blockage somewhare.
    Problem Solver:
  • 8 Answers
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Posted on Oct 13, 2008
  • 828 Answers
When the door heaters appear hotter than normal it is generally related to problems elsewhere. Refrigerator and or freezer not cooling. Check your temperatures inside. Clean your condenser(s). Check condenser fan motors to insure that they are operating.
Posted on Jun 21, 2008
Door sticks terribly...
First check to make sure that the hinges are securely fastened to the door jamb. Gently try to tighten all screws but be careful not to over-tighten or strip the screw heads. It's possible loose screws could be causing the door to hang slightly making it fit improperly into the door jamb.
It's also possible that the door frame isn't 100% "true" and it could be causing the storm door to get caught along the top or bottom edge. You can check with a level to make sure that both sides of the door are plumb (perfect 90 degree angle). You can also use a carpenter's square to check that all of the interior angles in the door jamb are 90 degrees respective to each other.
If everything is square then it could be that the hinges on the storm door are not aligned properly. With the storm door slightly ajar use a level on the vertical edge both at the top and the bottom. It should, ideally, be the same as the door jamb. If it's slightly off you could try shimming either the top or bottom hinge as necessary to even the storm door until it is aligned with the door jamb.
If you find that your door jamb is not "true" then you may need to consult with a carpenter or storm door installation expert to find a way to trim your storm door or refit it for easy opening and closing. Many older homes settle over time and sometimes door jambs slip out of alignment. The door itself may still open and close as usual but it may have sufficient gaps on all sides to prevent it from getting stuck. The newer storm door may be too tight a fit and catching on a door jamb that has settled out of true.
Feb 27, 2015 | EMCO Door. Forever 36 in. White Composite...
I have no power on all four door jambs 1996 honda civic hatch
After the fuse box, must be a multiple connector that sends the power to the doors, check it up, must be unplugged
Apr 04, 2014 | 96-00 Honda Civic Hatchback 3DR EK Spoon...
Door jamb switch
check at the bottom of the pillar just inside where the sealing rubber is on the door or check on the front door pillar near the bottom door hinge.
Mar 02, 2014 | 1992 Buick Century
Rewire a light box with four wires
I can help... but cannot see your drawing.
Let's get started:
1) By code, the microwave? should be on dedicated circuit
2) You have 4 cables that enter the box.
3) Only 1 cable will be Hot and Neutral from breaker box. You must identify this cable first.
Here is drawing:
http://waterheatertimer.org/images/Pantry-door-switch-1000.jpg
Apr 06, 2013 | Gardner Bender #GSW-SK Door Switch
Light won't turn off - very hot and heating up
HI. This is the direct result of a failed door switch. This switch controls the actual evaporator fan, as well. This dysfunctional switch must be replaced, asap. This replacement will correct your issues. The switch will generally be loctaed or mounted near the door jamb or recessed near the the door and unit structure intersecting areas or closing points. Once extracted, it can be tested for proper functionality with a ohm/multimeter.
Sep 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My 2002 explorers windows wouldnt go down unless the door was opened. My husband took it apart to see what the problem was and now the windows are stuck in the down position.
It could be a broken wire in the door jamb, check the wiring in the rubber boot in the door jamb, if ok then start checking the switch and the motor
Apr 10, 2010 | 2002 Ford Explorer
Doors seif locking all the time wont stay unlocked
Get to the bottom of this, the next step is a circuit hot when you do not want it.
Most of these issues happen in the door jamb. Are all of the switches looking non damaged? disconnect the switches one by one to eliminate them.
Move the bundle in the door jamb and see if you can affect the issue. There are no successul repairs in this area, replace at least the entire run throught the jamb, but ideally the whole loom that you have to get to replace the jamb portion.
Sep 13, 2009 | 1992 Subaru Legacy
The jamb between the freezer & frig is very
It is common to be warm to the touch. If it is excessively hot then your door heater may be going out. Have a technician check it out. If this fails the doors will begin to sweat and drip onto the floor. Hope this helps. Good luck.
Aug 15, 2009 | KitchenAid Superba KSRS27CN Side by Side...
I have a Hygena Built in fridge freezer and the freezer is defrosting and the fridge is not coming
hi try this On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Sep 13, 2008 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
594 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
