Question about HP Photosmart R707 Digital Camera
Background with horizontal lines and
I wish I could attach a picture to show you how bad the pictures come up! The colors are not working and the background show those fine horizontal lines.
I left the camera aside for several months due to the problem and when I tried it again, after charging it, I was able to take 2 FINE pictures then the problem started again.
The video area is working fine.
  • 2 more comments
  • Maijken Jul 06, 2008
    just have the same problem. my pictures are full of lines.
  • ntnear00 Jul 17, 2008
    It seems like all of us are experiencing this about the same time... my R707 has been my travel camera, and has been working great until the last few months. Before I had this problem with the colors and the horizontal lines, I had some issues with the buttons on the back -- the zoom and the center "Menu/OK" button and the up and down arrows would not work, but the left and right arrows worked fine! I took out the battery and put it back in, and that fixed the problem with the buttons. I had this happen about 4 or 5 times. And now I have the problem with photos themselves, that the other person asked about. I checked, and the video is fine, but regular photos are not. If anyone has a solution other than sending the camera back to HP (any idea what that would cost?) or getting a new camera, I'd love to hear it!
  • Willeke Nijland Aug 16, 2008
    I have the same problem since about 4 weeks now. I found after looking on the internet http://www.imaging-resource.com/badccds.... that it is probaly a problem with the CCD image sensor. Other manufacturers offer free repair after recognizing the problem with this sensor. It is what HP should do.... I suggest that everybody with this problem contacts HP..... Perhaps (after looking at the dates the problems started with your cameras) it is a new problem for the HP cameras..... Good luck!
  • bonnie11 Sep 09, 2008
    I have the same problem, it started a couple weeks ago. I don't know what a ccd sensor chip is, but I'd like to know if HP has repaired it for free for anyone so far. Also, did you know about the recall on this model for fire hazard while recharging?
    http://www.cpsc.gov/cpscpub/prerel/prhtm...
    Problem Solver:
  • 13 Answers
I have the same problem,, and i just talked with the supportgroup of hp,, and he told me it is the ccd chip,, it is broken, and you can get it fixed,, but it is cheaper for you to just buy a new camera,, hope i helped ya,,
Posted on Jun 26, 2008
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Sony Cybershot DSC-S500 bad photo resolution problem
Electronic shutter in lens mechanism got bad and you need to replace complete lens assembly of DSC-S500 camera.
Of course new lens assembly would cost more then camera worth so best option is to buy new camera.
Jul 23, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Picture Problem
In that set its usually a bad picture tube. The lines you are seeing are called retrace lines. You can take it to a shop and they may be able to rejuvenate the tube
Mar 13, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
HP Photosmart R707 Digital Camera Logo
164 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
