I can not open lime wire. message read one or mor files appear to be invalid. this is generally cause be corrupted installation. please try downloading and installing limewire again. please help me
  • 611 Answers
How to view corrupted rar?
RAR is the native format of WinRAR archiver. WinRAR tool is not only used to create RAR file but also used to repair corrupted RAR file or fix corruption from them. Whenever WinRAR fails to extract data from RAR archive, it means the archive is invalid or corrupted. You can repair the corrupted RAR archive by using the built-in repair feature of WinRAR application. All the required steps are shown below:
Solution #1
1) Open your WinRAR application.
2) Click on File tab and then click on Open archive. Or simply press Ctrl+O.
3) A new small window "Find archive" will be appeared.
4) Now locate your corrupt RAR file from the system directory and then click on Open.
5) Click on Tools tab and then click on Repair archive. Or simply press Ctrl+R.
6) Again a new small window "Repairing FileName.rar" will be appeared.
7) Now Browse the location where you want to save the new repaired archive.
8) The box "Treat the corrupt archive as RAR" is checked by default. But if it is not, then do check it.
9) Click on OK. The repairing process of selected archive will be started.
10) Once it is successfully completed click on Close.
Solution #2
RAR Viewer Tool - http://www.rar.viewertool.com/
May 06, 2015 | RARLAB WinRAR
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
Can't open download files
Either:
1) the original files are corrupt
2) the original files are encrypted
3) the downloaded files are corrupt
4) the downloaded files require being unzipped and you have no "unzipper" installed such as 7 Zip.
5) the downloaded files, if already unzipped, have no program assigned to read their specific format
Just what operating system were the files originally created upon and what software was used to create them? IF you don't know, try the followsing:
Determine their file type (their extension, such as .pdf, .doc, .jpg, etc.. Google "how to open "fill in" files (the file type). Try installing a program that reads that extension. If you already have one, try opening the file with a double click and when it asks for which program to use to open it, then pick the one already installed that your research says will open it.
It seems unlikely all the files would be corrupt. It is more likely that you do not presently have a program that can open that file type. You may have to convert the file type into another type of file for which you have software that can open it. Generally, there is freeware available that can open most file types.
Mar 04, 2015 | Computers & Internet
An invalid character was found in text content
I don't know what software you were using when this error occured, but it's likely this is some sort of encoding issue. Well, either that or the file is just corrupted. Generally, though, encoding issues such as this won't prevent a document from opening.
I've also seen this happen when you try and open a file with an application that is not intended to read it (e.g. trying to open a binary file with MS Word). Make sure you are using the correct application, as this is also a possible cause.
If I'm not making any sense, just know that I sometimes do that. I'd be happy to clarify if needed, just ask. ;-)
Oct 18, 2013 | Lenovo ThinkPad SL500 Notebook
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
Can i get themes for samsung champ
YOU CAN DOWNLOAD THE THEMES AT THE BELOW SITE......BUT READ THE NOTE BELOW
http://www.samsungthemes.net/category/samsung_themes/
Note:
If you have a problem installing .jar files and seeing "Downloaded Jar is Invalid" message, I recommend you to go to the service center and ask them to update/reinstall java installer as the installer of Champ gets corrupted as soon as you try installing (corrupted) files.
And if you have a problem with large .jar file size please do the following:
1.go to keypad in the main screen and then type the following code *#52828378#
2.select "OTA test" change maximum jar size from 500 to any number you desire (like 2000.)
3.Save it.
Now your phone is ready to install the java file not exceeding 2000 kb if you want to install java file of greater size increase the value (number)
Jan 25, 2011 | Samsung Cell Phones
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Have wrongly installed the driver and i want to uninstall the driver and re install it in my pc. when i try to uninstall the driver the following message appears. c:\windows\PIXTRAN\DR2080C.isu is eit
Are you uninstalling from Device Manager or add/Remove programs in Control Panel?
Try both methods ,disconnect the device first.
If it doesn't work then try to remove it in Safe Mode .
May 06, 2009 | Computers & Internet
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
