Can't connect denon S-52wireless network cd music system. searches for network and then displays 'no access point found' Owners manual not much help to me - all gobbleygook
  • 2 more comments
  • foxy3234 Jun 21, 2008
    How would I know?
    great
    the router is Linksys Wireless G ADSL Home Gateway Model No WAG200G
    the manual says it does it automatically.
    What is the wep key?
  • Lee A.
    Lee A. May 11, 2010
    are you sure that your router is not filtering MAC addresses?
    keep me posted.
    Thanks,
    Lee
  • 4,472 Answers
What is the make/model of your router.
Thanks,
Lee
Posted on Jun 21, 2008
  • 6 more comments
  • Lee A.
    Lee A. Jun 21, 2008
    sorry meant that to be clarification request not solution.
  • Lee A.
    Lee A. Jun 21, 2008
    Also you may want to try it wired to the router first and see if it works that way then set it up for wireless. As soon as I get the make/model of your router I will be able to help you further and we should be able to get this worked out.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    Also when you set up the wireless connection did you input the SSID and WEP key of your wireless network?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    you can do it automatically or manually. If you set up the wireless network it depends on whether or not you secured the wireless network if you have a wep key if you didn't secure your wireless network then you can leave it blank. the SSID is the name of the wireless network.
    If you need anything else let me know. I hope you will rate our premium session and find it FixYa worthy as I try very hard to provide fast and accurate information.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    Ok to set it up manually you go to
    "SETUP">
    "Network Settings">
    "Access Point Settings">
    "Details" setting>
    1. Input the SSID
    2. If there is a security select the encryption method
    3. Input the encryption key
    4. If selected wep use the default key, usually select 1
    Let me know how it goes.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    sorry I thought by no error message you were talking to me meaning you got it working.
    Keep me posted. I'm sure you will have it working once you have the correct info on your denon, and if it still doesn't work you have to access the router and disable the firewall and add the reciever to the allow list of mac addresses.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    If you get a chance and could rate our premium session that would be great as it looks much better if you accept a solution with 2 hours. I can help you the rest of the way through this if that is alright?
    I look forward to your help thanks,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    within* 2 hours.
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
How do you put inernet on your 3DS?
You will need an internet connection and wireless router. Turn on your DS and access the system settings by tapping the "wrench" icon. Next, tap "Internet Settings". Tap "Connection Settings." Tap "New Connection." Tap "Manual Setup." Tap "Search For Access Point." The DS will search for wireless networks within range and display the networks that it finds. Try to be close to the router when you do this, it helps the DS find the network. A picture of a lock will appear next to each router found. Locate yours. If the lock is open tap your network name and then tap "ok" to save the settings. Tap "ok" again to begin a connection test. If it is successful, you are now connected. If not, search the nintendo website for your error code and it will assist you. If the lock is closed, select your network name and a keyboard will appear. Type in your WEP/WPA key and tap "ok" when finished. Tap "ok" to save the settings. Tap "ok" again to begin a connection test. If it is successful, you are now connected. If not, search the nintendo website for your error code and it will assist you.
Aug 25, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Hownto put internet on the nintendo3ds
What You Need
  • A broadband Internet connection (cable, DSL, FIOS)
  • A wireless access point to a broadband Internet connection. Most people will use a wireless router or a Hotspot location.
Setup
  1. Turn on your Nintendo 3DS and access the System Settings by tapping the wrench icon.
  2. Tap "Internet Settings."
  3. Tap "Connection Settings."
  4. Tap "New Connection."
  5. Tap "Manual Setup."
  6. Tap "Search for Access Point."
  7. The Nintendo 3DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
  8. Look for your wireless network.
For More Info Check Here: http://www.nintendo.com/consumer/systems/3ds/en_na/ht_internet.jsp
Jul 31, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
I need to know how to connect my dsi and I can't. I need to know what the security key is to connect to my wireless.
A broadband Internet connection and wireless router are required. Follow the steps below to get connected.
  1. With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
  2. Access the Nintendo Wi-Fi Connection settings. (These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.)
  3. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  4. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  5. Click on "Search for an Access Point."
  6. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network. (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DS.
Jul 15, 2011 | Nintendo DSi White Console
How do you get internet
Here is a step by step guide on getting connected with your DS system.
Apr 25, 2011 | Nintendo DSi White Console
How to set the setthings of nintendo to connect enternet
  7. If your wifi is password protected, it will ask you to put in your password. Otherwise just tap on your network name and hit ok, save settings, and then yes.
Mar 02, 2011 | Nintendo Dsi Pink Console
I just bought a Nintendo DS I and I want to know how to use the internet?
Let's get you connected!
    Tap on your network name to select it.
    Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
Jan 30, 2011 | Nintendo DS Lite Console
PS3 Wireless issues
Network settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet using an Ethernet cable.
1. Connect an Ethernet cable to the PS3™ system.
2. Select (Network Settings) under (Settings) in the home menu.
3. Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
4. Select [Easy].
After you confirm the network configuration, a list of settings will be displayed.
Depending on the network environment , additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
5. Save your settings.
6. Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
7. Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Internet Connection Settings (wireless connection)
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1. Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2. Confirm that an Ethernet cable is not connected to the PS3™ system.
3. Select (Network Settings) under (Settings) in the home menu.
4. Select [Internet Connection Settings].
5. Select [Easy].
6. Select [Wireless].
7. Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8. Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9. Check the SSID for the access point.
10.Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11. Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12. Save your settings.
13. Test the connection.
14. Confirm the connection test results.
Internet Connection Settings (advanced settings)
If you are unable to connect to the Internet with basic settings, change your settings as necessary. Adjust each item as necessary for your particular network environment.
1. Select (Network Settings) under (Settings) in the home menu.
2. Select [Internet Connection Settings].
3. Select [Custom].
Adjust each item as necessary for the network environment in use. The items displayed vary depending on the settings you have selected.
Connection Method
Set the method for connecting to the Internet. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Wired Connection
Make a wired connection using an Ethernet cable
Wireless
Make a wireless connection via a wireless LAN
WLAN Settings
Set the SSID of the access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Scan
Scan for a nearby access point.
Select this setting when you do not know the SSID of the access point. The system will detect nearby access points and display information on the SSID and security settings.
Enter Manually Specify the access point by entering its SSID manually using a keyboard.
Select this setting when you know the SSID.
Automatic U
Use the automatic setting feature of the access point.
This setting is available only in regions where PS3™ systems that support this feature are sold. Select this setting when using an access point that supports automatic setup. Follow the on-screen instructions.
WLAN Security Setting
Set an encryption key for an access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set an encryption key.
WEP Set an encryption key.
The encryption key can be entered on the next screen. The encryption key is displayed as a series of asterisks.
WPA-PSK / WPA2-PSK
Authentication Setting
These settings are available only on PS3™ systems sold in Korea and are available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set authentication information.
EAP-MD5 Set authentication information when using public WLAN services.
Enter your user ID and password on the next screen. For details, refer to the information supplied by the public WLAN service provider.
Ethernet Operation Mode
Set the Ethernet data transfer rate and operation method. Usually select [Auto-Detect].
Auto-Detect Automatically set basic settings.
Manual Settings Manually adjust the Ethernet data transfer rate and operation method.
IP Address Setting
Set the method for obtaining an IP address when connecting to the Internet.
Automatic Use the IP address allocated by the DHCP server.
You can enter the DHCP server host name on the next screen.
Manual Set the IP address manually.
You can enter values for the IP address, subnet mask, default router and primary and secondary DNS on the next screen.
PPPoE Connect to the Internet using PPPoE.
You can enter your user ID and password on the next screen.
DNS Setting
Set the DNS server.
Automatic Automatically acquire the DNS server address.
Manual Manually enter the DNS server address.
MTU
Configure the MTU value used when transmitting data. Usually select [Automatic].
Automatic Automatically set the MTU value.
Manual Specify the maximum size of data packets (in bytes) that can be sent in one transmission.
Proxy Server
Set the proxy server to be used.
Do Not Use Do not use a proxy server.
Use Use a proxy server.
You can enter the proxy server address and port number on the next screen.
UPnP
Set to enable or disable UPnP (Universal Plug and Play).
Enable Enable UPnP.
Disable Disable UPnP.
Nov 09, 2008 | NetGear WGR614 Wireless Router
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
If you select [Test Connection], the system will connect to the selected access point.
14.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
 Grubhead
Grubhead
