Question about Belkin Computers & Internet
Keep getting i/o error message from my external hard drive when i want to copy a file from it to my computer
  • 611 Answers
If you using throught usb port then chnage the port and re-connected hard drive
Posted on Jun 21, 2008
While copying the files from C drive it started giving Error: 080070057
Can you copy those files to a USB memory-stick?
Do you get any error-messages when reading from your 'C:' drive?
If yes, then your 'C:' disk-drive is "dying".
If no, then your disk-drive is OK, and its the external storage device that is "dying". Make a backup of the files on that device, if you can.
The only "good-news" is that the Seagate probably still is under warranty -- Seagate will replace it, at their cost, not your cost.
Oct 23, 2010 | Seagate FreeAgent Pro 1TB External USB...
Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Archos AV700 Digital Media Player
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
I get a runtime error message when i try to open encrypted files on my i/o magic external hard drive
Computer virus generates a runtime error. Ensure that your anti virus software is updated and scan your hard drive completely before opening files in your external hard drive
Feb 27, 2010 | HP Computers & Internet
I have a 500g external simple drive. i am getting a message that i can only read on my mac.
Copy all the data onto your Mac computer.
Take the external drive to a PC computer, and "reformat" it, using "quick format".
Take the external drive back your Mac computer,
and write all the "saved" files onto the drive.
Nov 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
Cannot read/write
Try both moving it to different computers and reinstalling drivers.
Feb 14, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
I/O device error Lacie mini ethernet drive
- Try to install proper drivers for your operating system.
- Check if your device is supported with that server/pc ? does server supports USB2.0 ?
Update NIC drivers to the latest level
Aug 02, 2008 | Computers & Internet
Hp Pavilion a1220n -- Copy file errors when Installing windows
Maybe I can help;
When I install a new hard drive I like to re-install the operating system (OS) as well. Unfortunatly this wipes out all your files.
Typically when files do not copy it's either because they're in use or the media (your new hard drive) is not formatted properly.
Note, formatting erases everything on the drive being formatted.
Instruction for this are easy to find online but are all done for you if you use the OS install CD which will walk you through the setup, formatting, and partitioning.
If you have a way to save your files to another drive such as a usb thumb drive, external hard drive, cd or dvd, I would go about it that way. There's usually alot of uneeded files created by the operating system after a period of time and there's no sense in keeping them. They only slow your system down.
One other thing you can consider if you don't have an external hard drive is purchasing a hard drive enclosure for your old hard drive. You can find them at Best Buy. I paid about $30. Its just a case and usb cord you can use as an external hard drive and also copy any files you can still access on this old drive over to your new one.
Let me know if this helps you
Apr 20, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Computers & Internet Logo
23 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
