Question about Conair GMT182CS
Fell apart..help please!!!
Hi guys, my conair trimmer wasnt working properly, so i decided to unscrew the top part(the blade part) and i now i have 4 parts and dont know how to put it back together, i have 2 pieces used for the actual trimming, and 2 white pieces, one which has 2 spring like structures attached to it....thanks for anyhelp...
  • Anonymous Mar 26, 2014
    conair hc500c blades fell apart
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
  • aces_1n_only Jul 09, 2008
    I would also try calling the customer service number on the razor 1-800-3-CONAIR, they may be able to help you. There may be a warranty. Let them know there was something wrong with it to begin with and you tried fixing it. I did that one time with another product and they shipped me the parts. Sometimes they do it as a courtesy.
I have Conair GMT189CGB do I have to remove the hair blade every time I want to change attachments? If so, this seems to be a royal pain.
Posted on Jan 21, 2010
If you call conair don't say that you unscrewed anything because that will void the warranty and then you will be screwed. Tell them that it is stuck and you need help. They might just send you a replacement head.
Posted on Sep 21, 2009
Hey thanks ALOT for the solution, but i still cant understand where the white piece with the spring attached to it is supposed to go, if i dont attach this piece to the machine, everythin fits perfect, and when i try to add this in, it dosnt fit together, any additional help would be greatly appreciated ... thanks...
Posted on Jul 19, 2008
How can i conair deluxe beard rechargeable beard & mustache trimmer
It sounds like it was taken apart by someone else???. Conair has a web-site which should give you diagram for putting it back together. Hopefully, all parts are there and undamaged.
Dec 07, 2014 | Conair Deluxe Rechargeable Beard &...
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
Plug in charger fell apart - need to replace
Hello. Go directly to the manufacturer. Here is the phone information
Mar 28, 2010 | Conair GMT200TD
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Mar 23, 2010 | Conair HC117 Hair Trimmer
Clipper Blade
the bottom blade has to be put back in place. Unscrew the two top screws and remove the top blade. fit the the bottom blade on the plastic piece. Replace the top blade and screws
Mar 19, 2009 | Conair HC100RCS Hair Trimmer
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Conair GMT182CS Logo
1,364 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
