Question about IBM ThinkPad R50e Notebook
Laptop won't power up
I am having trouble. My IBM Thinkpad won't power up.
One day i was using it, and when i got home, it would no longer power up.
I know the battery still had a charge before i closed it down, and now I can't get it to power up at all.
Please help
If you are just using the battery, the power plug that supplies power to the laptop may be the culprit, if you are using the plug in power supply and there is still no power at all , you might have a power converter problem. check female part of plug on laptop for any looseness either way a tech. is needed to prove conductivity and connections inside laptop
Posted on Jun 22, 2008
  • 105 Answers
This is something that unfortunately will require a technician to figure out. It could be the motherboard is gone, it could be the power supply is gone, or it could be any number of other things.
You did not specify, but if it is doing absolutely nothing I would be inclined to think it is indeed something major.
Sorry for the bad news.
Posted on Jun 21, 2008
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display '
Sep 11, 2012 | IBM ThinkPad G41 Notebook
IBM Laptop Battery Power Saving Tips
How to try to extend the battery life are much concerned by many laptop users. Utilizing some small skills and minimize unnecessary waste of battery during the using process can make you full use of your laptop battery power.
The engineers of IBM personal computer business division give vast laptop users some good suggestions here to ensure that you can maximum extend laptop battery utility time. Therefore, it will improve your work efficiency; let you enjoy mobile office work and entertainment pleasure without limits.
IBM batteries on sale :
IBM thinkpad t40 Battery £ 37.52
ibm thinkpad t41 battery US $ 41.24
ibm thinkpad r60 battery. US $ 71.27
IBM ThinkPad T60 Battery £ 38.51
* Turn down the brightness of the screen. At the same time, although IBM ThinkPad laptop keyboard is equipped with lights, ThinkLight, but in order to save power, it is better to turn on it when under darkness conditions.
* When not using the wireless receiver device, turn it off please.
* Some users like opening CD or DVD to play music anytime, the power of battery will flow away quietly along with the music playing. Suggest everybody turn on the music only under the situation that they do want to enjoy the music.
* When the battery during using process, try to fully charge and discharge the battery.
* Try to avoid using it under high temperature and low temperature, for example, when you enjoy sunshine on the beach, please don’t leave your laptop in the car to enjoy SAUNA.
* Use proper AC adapter for your ThinkPad laptop.
* Use the IBM ThinkPad battery Battery MaxiMiser management software you select the most suitable for the extension of the power program.
* Use the IBM ThinkPad battery management software – Battery MaxiMiser, select the power extension program which suitable for you.
* Setup the standby time of monitor, hard disk and system sleep time, because it is no need to let your laptop still running at full load when you are at non-working stage.
* Under the Intel SpeedStep technology effect situation, the processor based on the current load situation adjusts the speed automatically to save battery power overall.
In fact, the laptop battery is a spiritual guy, after got expert advices, please treat it properly, it will bring you to enjoy a better mobile life.
battery info via:
on Jun 04, 2010 | Computers & Internet
Hello my question? can i operate my IBM r52 thinkpad with out a battery? because the battery will not charge and the thinkpad will not operate with the power cable?
Remove the battery and connect the laptop with the charger and it should operate normally. However, in the absence of battery you won't be able to get backup.
Hope it helps! Good Luck! Thanks for using Fixya!
Sep 09, 2011 | IBM ThinkPad R52 Notebook
My ibm thinkpad won't turn on
Try powering on laptop what happens do you hear any beeps or see any lights normally if u see lights this is a sign that it is working if not your motherboard could be bad if you see lights and hear constant short beeps this means your memory can be bad, Try powering on laptop without battery and only power supply plugged in.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
How do you lighten the screen on the ibm a20m laptop computer?
Hello sandee232,
The following key combinations can be used for screen brightness:
•Fn + PgUp Turn the ThinkLight on or off.
•Fn + Home The LCD becomes brighter.
•Fn + End The LCD becomes less bright.
The screen brightness information can be located inthe IBM ThinkPad A21m User guide:
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
Feb 04, 2010 | IBM ThinkPad A21m 2628 Notebook
Not able to read dvd's and able to read cd's model lenovo 510i
While I was not able to find that specific model of laptop, I was able to locate the CDRW Bay and based on my research this bay only supports the following models. Though it may look the same and even have the same interface, if it is not in the supported model list, it will not properly function.
Supported Media Types:
  • CD-ROM
  • CD-R
  • CD-RW
Compatible with:
  • IBM Lenovo ThinkPad R50
  • IBM Lenovo ThinkPad R50e
  • IBM Lenovo ThinkPad R50p
  • IBM Lenovo ThinkPad R51
  • IBM Lenovo ThinkPad R51e
  • IBM Lenovo ThinkPad R52
  • IBM Lenovo ThinkPad T40
  • IBM Lenovo ThinkPad T40p
  • IBM Lenovo ThinkPad T41
  • IBM Lenovo ThinkPad T41p
  • IBM Lenovo ThinkPad T42
  • IBM Lenovo ThinkPad T42p
  • IBM Lenovo ThinkPad T43
  • IBM Lenovo ThinkPad T43p
  • IBM Lenovo ThinkPad T60
  • IBM Lenovo ThinkPad T60p
  • IBM Lenovo ThinkPad X40 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad X41 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad T30, X30, X31, R40 series (2366, 2367, 2884, 2885, 2681, 2682, 2683, 2896, 2722, 2723, 2724, 2897, 2672, 2673 - when installed with the optional ThinkPad Slim Drive adapter for the UltraBay 2000 or X series UltraBase or Media Slice)
If you see your model in this list comment back and we can move forward with getting your issue resolved.
Good Luck,
Jan 29, 2010 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
I forgot my power-on password for my ibm thinkpad t60 and i can no longer use it. is there a way to remove the password so i could use the laptop?
take it apart and remove the bios battery on the motherboard,remove main battery,set something heavy on power button to hold it down and wait,maybe a day ,or a couple hours ,it varies ,sometimes doesnt even work,but this one should reset,reassemble and power up ,good luck ,hope this helps.aloha from maui todd0708
Oct 22, 2009 | IBM ThinkPad T60 Notebook
Using T42 in car having trouble seeing screen on bright days
When you are driving a car or vehicle, you should not be using any sort of device that distracts you from ¨driving¨. Goes for ipods, laptops, cell phones, etc...
Feb 22, 2009 | IBM ThinkPad T42 Notebook
Do not under any circumstances turn it on for a couple of days.It should of not been turned on whan it got wet. You could of fried the motherboard. Let it dry till Monday, then you will know if the damage is done.
Nov 10, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad R50e Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
