Question about Infinity KAPPA 62.1I Car Speaker
Car speakers I installed new speakers in my door because the previous ones i had to turn the radio up at a high volume to hear them. Now im still having the same problem with the new ones. what could be the problem?
    President:
  • 624 Answers
It is not the speakers, since you replaced them and still have the problem you can rule them out.
Check the fade function on the radio. You may have the fader set to mostly the rear speakers.
You did not give the model number of the radio, but most aftermarket radios have a reset button on them. if you can not find the fade setting, you can always reset the radio and see if that helps. it will clear all your memory functions like the clock setting, the preset stations, fade, balance, treble, bass and set it to the original factory settings. if you can not find a reset, there is one other option but if your radio uses a security code make sure you have the code before doing this because you will need it.
Just disconnect the car battery for about a minute and then re-connect. That should reset the radio also. But remember......if you have a security code and don't know it, you will not be able to power the radio back on again. You will have to pay a shop or dealership to clear the code, depending on what kind of radio you have.
I can help you with Kenwood codes but you need the remote to clear the code with those.
I hope this was helpful, let me know if you need any more help. if this fixes you up, a good rating would really be appreciated. have a great day.
Dave
Posted on Jun 21, 2008
    Problem Solver:
  • 7 Answers
The speakers have were not ur problem the radio was. the speakers can only go as high as the radio can. there r 2 ways 2 slove this get a new radio, or add a amp to run the speaker. contact me if u have any more ?s.
Why is there no sound from my speakers but the radio is on
easy check to carry out ,borrow a speaker that you know works, if you remove one from another vehicle make sure ignition is off when taking speaker out, take a speaker out from your vehicle ignition off , the door speakers are usually the easiest to remove,plug in the known good speaker to your vehicle turn ignition on then radio, if you get sound then the problem is with the speakers but very unusual for all speakers to blow at the same time unless there has been a power surge through the amp. if no sound still remove radio and make sure the wire connectors are pushed home securely if they are then it's most likely the radio is not working will need replacing as a repair can be more expensive than new
May 04, 2014 | 1999 Chevrolet Monte Carlo
Installed new radio in 95 oldsmobile cutlass ciera and speakers dont work
you may need new speakers or there are wires not hooked up right
Oct 29, 2017 | 1995 Oldsmobile Cutlass Ciera
I cant lower the volume, in fact many times volume increases when trying to lower the volume and im getting sound out of only the driver side speakers
MOST LIKELY YOU WILL NEED TO REMOVE RADIO AND HAVE IT REPAIRED. OR INSTALL A NEW RADIO. HOPE THIS HELPED. MOTOR 62500...
Dec 21, 2010 | 2002 Mercury Sable
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
Protect is across the screen
i'm guessing you have a kenwood... you will have to get to the back of the radio and unplug it for a couple of minutes then plug it back in.
this happens when you turn the volume up too much or you have a blown speaker (may hear it rattling around and it probably sounds ok at lower volumes) that is registering lower than nominal impedance around 3.8 ohms or so. if you have recently installed new speakers and this is happening it is possible that one of the speakers' terminals is resting on the metal area of the door or rear deck or a speaker wire has been drilled through during installation. this will cause a drop in impedance and therefore result in the same symptom you are experiencing.
Aug 18, 2009 | Kenwood KDC-MP332 CD Player
1991 Ford Taurus SHO high-level audio system troubleshooting
Look into your owners manual and find the fuse diagram-it may be that your sound system has 2 fuses for the audio system. I had the same problem in my explorer with the "premium" sound system -and it was a fuse-one said radio etc. and the other said audio system-so im guessing that one ran the deck and one ran the amp-anyhow i changed it out and it worked fine-hope that helps ya
May 11, 2009 | Car Audio & Video
Very low sound out of left front speaker, other speakers work fine
Have you tried another speaker? If your left front speaker is in the door as in most cars, it gets banged around a lot. The driver's door gets the most use. This sometimes results in mechanical problems with the speaker, and can cause low sound or distortion. Take the speaker cover off (it may be necessary to remove the door panel in a factory installation), disconnect the speaker and hook another in its place. If the volume is back to normal you know it's the speaker. If not, check the radio and speaker wiring. If the radio itself is at fault because the amplifier is bad, it can be repaired at a service shop. The repair charges might be close to replacement cost these days, so you might consider a new radio if the estimate is high.
Apr 27, 2009 | Sony XR-M510 Cassette Player
MY FACTORY RADIO VOLUME PROBS
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
E
E
Mar 02, 2009 | 2003 Chevrolet Silverado 1500
Infinity KAPPA 62.1I Car Speaker Logo
250 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
