Question about Bissell 1770 Quicksteamer II Upright Vacuum
How to fill the clean water tank??? - Bissell 1770 Quicksteamer II Upright Vacuum
The clean water tank cap is two-part. Unscrew the threaded ring and then pull out the center piece. There is a rubber gasket around the center piece, so it may take light force to remove it. Fill the tank with solution to the "solution" line, and fill with hot water to the "water" line. Cheers.
Posted on Aug 17, 2008
Used bissell how do i know if parts are missing
The main water tank is two staged; you put clean water in and the flexible bladder allows the machine's pickup suction to fill. This removes the need for two tanks (but it's harder to clean out the suction tank area). Just remember to clean the filters each use. There's one on the underneath of the clean water tank cap and one under the FLOW INDICATOR cap. You may need to get a User's Guide. Try calling the Consumer Care at 1-800-237-7691 Hope that helps.
Apr 03, 2015 | Bissell Vacuums
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
My scooba isn't picking up any water and the dirty tank is dry
This has happened to me twice. Frustrating. The first time I fixed it by half way filling up the dirty tank side, shaking the living bejeezes out of it, rinsing, and repeating a few times until big nasty clumps of **** fell out of the tank. The second time I was able to fix it by half way filling both sides of the tank (clean and dirt sides) with salt water, shaking the living bejeezes out of it, rinsing with fresh water, and repeating a few times with fresh water until big nasty clumps of **** fell out of the tank.
Jan 23, 2009 | iRobot 5800 Scooba Vacuum
Amounts of Solutions
From the manual:
1. Remove the Clean/Solution Tank by lifting it
straight up, then away from the Lower Body.
2. Unscrew the black cap at the bottom of the
Clean/Solution Tank.
3. Add one of the BISSELL Advanced Cleaning formulas
for Deep Cleaning machines to the formula fill
line on the Clean/Solution tank. Fill the rest of the
tank with hot (not boiling) tap water to the water
fill line. Replace and tighten the black cap.
4. Place Clean/Solution Tank on Lower Body.
The manual is available at retrevo.com, but you have to register to get it. It doesn't open up so that I can link you to it. It doesn't cost anything though.
Hope this helps!
Dec 08, 2008 | Bissell 1770 QuickSteamer Upright Vacuum
Bissell 1770 Quicksteamer II Upright Vacuum Logo
273 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
