Question about Kenmore 15129 Built-in Dishwasher
Dishwasher My dishwasher is accumulating water on the floor of it and not being drained out. What do I need to do to fix this problem? Also, what is the average time for a brand new dryer to dry clothes? Any suggestions are appreciated.
  • Darts11 Jun 23, 2008
    I am having the same problem. I checked the drain pipe/tube connected to the disposal and it is not obstructed. Other than that I see no way to check for any buildup anywhere. There is nowhere/way to lift up the impellor and what is the boppy plastic in the right front of the base within the washer????
  • 5,911 Answers
Dishwasher: I'm assuming you are talking about when the dishwasher is not running. Correct? If the dishwasher accumulates water while sitting idle, it could be a couple of things. The water inlet valve could be leaking by, or you may have an improperly installed drain line. If you do not have a high loop in the drain line, water can back feed into the dishwasher when you drain your sink. Some dishwashers have a check valve on the drain line to prevent this.
Dryer: Dryer times will vary depending on the load size and type of clothing. Properly sort laundry to make sure lighter materials are separated from denser clothing that holds moisture. For example, if you attempt to dry jeans or towels with light cottons or linens, the moisture from the denser material will transfer to the lighter material. This can cause longer dry times. Towels and/or jeans should be dried on a hotter temperature setting - usually takes 30 to 45 minutes. Cottons and linens will take about 30 minutes on a lower heat setting. Make sure the dryer exhaust vent is not clogged. If the dryer cannot exhaust properly, the dryer heating circuits will actually overheat and eventually fail. The result is a hot dryer with clothes that will not dry. If you suspect you have a dryer vent problem, remove the vent hose from the back of the dryer and try drying a load. If your drying results improve, you probably have a clog in the dryer vent EXTERNAL to the dryer. If the results are the same, inspect the dryer INTERIOR. NOTE: Rule of Thumb - The SHORTER and STRAIGHTER the dryer vent, the better. Dryer vents that are excessively long, have many bends, or run through an attic or crawl space are the worst for accumulating lint. Also DO NOT push the dryer all the way up against the wall. This tends to crush the exhaust vent hose. Leave about a one foot space between the back of the dryer and the wall and use the semi-rigid metal type dryer vent hose. It resists crushing and rodents from chewing through it.
If you would post brand name and model numbers of your appliances in the future, it would make it much easier to diagnose a cause and be able to tell how the appliance is configured. I hope you find this information helpful.
Posted on Jun 21, 2008
Won't drain
I found a video that explains how to fix this issue, here is is.
Bosch Repair video
Feb 06, 2011 | Dishwashers
Motor keeps running and we can't operate the dishwasher
Look for water accumulating under the dishwasher. It has a tray that will catch any leaking water before it gets to your floor. If this is the case the most likely cause for the leak is the drain hose (located behind the main pump housing).
Jan 12, 2011 | Viking 24 in. Professional Series DFUD140...
Dishwasher not draining
Thanks for writing to
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Over flows water on to the floor when operating
as the question states, the floor drain overflows a little (but enough to be annoying) when water is run any where in the house. I rented a motorized snake machine and did that, pulled up some stuff but didn't fix the problem. We have had a ton of snow lately and it is starting to melt. Could this be part of the problem or do I need to call the plumber? Thanks in advance.
Apr 03, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Frigidaire Dish washer MODEL
hi there the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher accumulates a pool of water long after use
hi there,
if the water is outside of the d/w, on the floor infront, you may need to have the door gasket replaced
if the water is inside in the tub, the d/w is not draining. check the drain pump for anything caught in it, like coins, hair or food pieces.
can you provide me with the make and model off the dishwasher?
Sep 25, 2008 | Dishwashers
Dishwasher accumulates water
your valve will be on bottom but they are sometimes not to hard to get to also you do not have to change the valve some of those selanoid valves are expensive and the do make seals and or o-rings to fix those valves i fix them quite often the only time you have to change the whole valve is when the selanoid burns up if you can give me the serial and model #s plus brand and make i may be able to find out what we need to do to get you leak free with out breaking the bank
Nov 09, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Kenmore 15129 Built-in Dishwasher Logo
167 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
