Question about Dryers
New Whirlpool Dryer taking too long to dry
I don't know the average that it takes a large load of clothes to dry, but I just bought a new whirlpool front load dryer and it takes about 120 mins. for this thing to even retract moisture from the clothes. I had a 20 year old hotpoint dryer that I never had a problem with. I could dry clothes in about 40 mins and they come out crisp and hot. I'm wondering if I made a mistake on purchasing this item.
  • rissae Jun 21, 2008
    Thank you for your suggestions, I will try that right now.
  • 246 Answers
Old dryers worked on the premis, "bake them til they are done". Newer dryers are all about saving energy. Newer dryers rely far more on airflow than thier predecessors. Most likely if your clothes are taking 120 minutes to dry for a new dryer, you have a ventalation problem. Make sure (even if it was "professionally" installed) that the vent from the back of the dryer to your wall in not kinked, bent over, or other wise restricted. Also make sure when the air is venting to the outside of your house you can feel a fair amount of air pressure there. Bulid up over time or even a nest being built in your vent can cause a restriction on airflow. These can be cleaned by a professional service or many appliance and hardware sell cleaning brushes and kits. Worse case scenario, Whirlpool will pay for customer instructs for the first 6 months. So even if they have to come out and tell you it's a problem with your house vent or electrical supply, whirlpool can be billed for this. Of course if there was a manufacture defect off the production line, repairs are still covered under warranty as well.
Posted on Jun 21, 2008
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
Dryer runs and has heat, but takes 3-4 cycles to dry
inspect your dryer vent if it is clogged or has standing water in it, that will cause your problem
May 12, 2009 | Dryers
Relatively new dryer takes several cycles to dry normal loads
Check the lint trap all the way down to vent, then make sure that the vent is not crushed in anyway. Depending on the way the person cleaned it they could have actually caused more of a clog
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Dryers Logo
121 people viewed this question
Top Dryers Experts
