Olevia 227-S11 27 in. LCD TV Logo
Posted on Nov 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get the hd channels on my tv? - Olevia 227-S11 27 in. LCD TV
Chi Chu
Level 3:
  • Olevia Master 8,457 Answers
  • Posted on Nov 20, 2010
Chi Chu
Olevia Master
Level 3:
Answers
8457
Questions
0
Helped
2820868
Points
26282
Check the tv station ur tv is on.Press the button on the remote that said DISPLAY.U see the channel reslotions are on 1080p or 1080i ur tv is playing in HD channels.
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
6008
Points
80
Do you have an HD box? Or anything connected for tv service?
  • hollynarf Nov 20, 2010
    moved the tv from one room to another and lost the hd channels. there was never any box its an hd tv.
I have an old AWA tv which is an HD LCD tv and now SBS has changed to 31channel and their movie channel is no 32 I can't get either, sound is there but no picture. I've gone through automatic tuning,
Are you sure it's a HD TV? Channel 32 is now a high definition channel so if your TV's not HD you won't see anything. the sound should come through but it's lots quieter. Can you see channel 95? it's also a new HD channel. You should get 31 though,
1helpful
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
CANNOT GET HD CHANNELS
You need HD cable box to get HD channels from cable.
1helpful
Pixilization on non hd channels with hdmi cable connected to HDPVR receive. HD channels come in crystal clear, non hd channels are all bitmapped and horrible
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Looking for hd channel
To get an hd picture you have to use a digital input and this cannot be done by simply turning it to a channel. You need to hook up your HD receiver (box) to your tv using either an HDMI or a Component which will be a cable that looks similar to an rca but there are three of them and the colors are bed blue and green. If there is a red, blue and green on the back of the cable box and the tv hook them together with a component cable and then find the input on your tv that correlates to the compnent connections and then even after all of this you need to be tuned into a channel that is offered in high definition and if you have cable like I do the high definition channel will be a seperate channel from the regular one. Comcast in my area puts the HD's from channels 400-500. For example my espn HD is channel 403 but just regular espn non HD is on channel 27 in my area.
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
