Question about Canon PowerShot A75 Digital Camera
Canon Powershot A 75 Digital
Lens won't open and E 18 appears on screen
  • Tim Babcock
    Tim Babcock May 11, 2010
    Well the owners manual wasn't much help. Does it do the same thing when you plug it into an electrical outlet?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jul 31, 2012
t00nz
  • 4738 Answers
SOURCE: Help Canon powershot A300
Had the same problem with my A300. This sounds a defective CCD imager. If so, Canon should fix this for you for free under a recall. THIS INCLUDES FREE SHIPPING both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Nov 23, 2007
kevin000
  • 1847 Answers
SOURCE: canon digital ixus 75, 3
formate the memory card and then try
Posted on Jul 05, 2008
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
Posted on Sep 15, 2008
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have a canon powershot sx100 IS the lens is
Here is a site that discusses things you can try to fix this for free. They do a much better job than I could, and they let you know the risks and steps to take, in order. Try this first, you might get lucky- they say 50% of stuck lenses or lens errors can be fixed.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Don't worry, this is a huge problem with extendable lenses, due to their construction with small, plastic gears that are easy to break with a bump or fall, or obstruction while extending.
Posted on Apr 18, 2010
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
E18 came up on the LCD screen. The camera will not operate.
E:18 is a standard "lens error" message for Canon cameras. If the lens is stuck at an angle, then sometimes you can SNAP it back towards center and make it work again. If it's not at an angle then you will need to replace the lens assembly. A good refurbished lens install is about $75, so you have to weigh that against buying a new camera for $200 or sending the camera to Canon to fix for $125.
Hope this helps.
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Water spot behind lens ?
the lens has to be replaced repair cost is 85.00 for this to be done.
Jun 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon camera when turned on, lens will not
Hi
What you are seeing is a generic error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
Faulty Canon Powershot A410 Digital Camera
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot A75 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
