Question about Lands Phones
Panasonic tvs-100 voice mail beeping and flashes red power light four times
Panasonic tvs-100 connected to Panasonic kxtd1232 cabinet as port 165. voice mail was working fine this morning. Power was turned off to both main cabinet and voice mail. Main system working fine but voice mail cabinet is not.
  • sirswong Jun 27, 2008
    We have a similar problem. After re-installed our kx1232 phone system with the tvs100 voice mail box. The red power light was flashing and the red lights in the phone set kept running on each extension line again and again. The phone man said the hard drive was mulfuction so ask me to replace it! Is that the case? Any solution?
  • Anonymous Oct 29, 2008
    Our TVS-100 seems to be down (but the phone lines still work). The power light is blinking and the manual does not specify what that means.
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Posted on Dec 03, 2014
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7633 Notification Light will not turn off
The red light is MESSAGE WAITING. It is not necessarily VM notification. Press the MESSAGE button and look at the display. One of the soft keys will let you CLEAR the message and it will tell you where it came from. It's set by anybody calling your phone, and randomly, it is set by dialing your extension plus "4". Oops. It's a Pana mystery :-)
Carl
Posted on Jul 08, 2010
SOURCE: Panasonic KXTD1232
1234
Posted on Mar 27, 2010
SOURCE: Red light on.
Press the "message" button and an option for "delete or save number" will appear. That's it!
Posted on Jan 05, 2010
cnavarro
  • 2460 Answers
SOURCE: My Panasonic Phone KX-T7630 rings
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
Posted on Jun 29, 2011
  • 102366 Answers
SOURCE: re-setting voice mail indicator
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Posted on Sep 01, 2012
Testimonial: "Thanks! It worked. Confusion between phone system and provider system."
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
We have a business panasonic xdp system and are unable to change the greeting message. How do we access this initial contact message. We are able to change individual mail boxes on the system.
Assuming you dial 165 to get to the voice mail system (a TVS type box) you press #6 * 998. You better know the password if it asks and you need to know where the greeting was recorded. It sits either in a Custom Service box (1-100) or a Company Greeting (1-32).
I'd be hoping that someone left a TVS Installation and Programming manual with cheat notes lying around. If not, there's a way into the TVS via a terminal program and the DB-9 serial connector on the box. That will let you read the database.
Your Panasonic installer/dealer might have the passwords and setup in their records.
Carl
Jun 28, 2011 | Panasonic KX T7220 Corded Phone
We have a Panasonic KX T7436 phone in our office but the manual doesn't tell us how to change the voicemail message for when the phone isn't answered. Can you assist?
It doesn't tell you because the voice mail system is a separate part of the TD system. There are instructions provided with the Voice Mail system. In a Panasonic brand TVX you access it by dialing 165 and control it from either the serial port, a USB port, or mailboxes 998 and 999. 998 and a set of instructions give you access to message recording. If you don't have the instructions, you need to contract whoever set it up or find the MESSAGE MANAGER guide.
Rather than play GuessYa, comment back with the VM model number. It's either a smaller white or black/blue box mounted near the main phone system cabinet.
Carl
Apr 21, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
Panasonic kx-t7453 corded digital super hybrid system How do I turn my voicemail box on so a caller can leave a message at my extension? thank you
Pretty much, it depends on what happens when you dial 165. That's the voice mail access number for a Panasonic TD phone system with Pana VM. If you get the voice mail lady, set the box up and then from the intercom dial 7102/3/4/5 where 2 is all/3 is busy, 4 is no answer and 5 is busy/no answer and 165 or whatever the VM access number is and possibly # (I forget if it's required). That will light the FWD/DND light and send calls to the voice mail system.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
Free instruction to record my voice kx t7730
The 7730 is a PHONE. It connects to a Panasonic PHONE SYSTEM CABINET and Panasonic VOICE MAIL SYSTEM. The voices you hear are stored in the VOICE MAIL SYSTEM and it varies by model number and installation. Typical messages are stored in CUSTOM SERVICE menus, of which there are
100.
It is changed by accessing mailbox number 998 as message manager.
Carl
Dec 18, 2009 | Panasonic KX-T7730 Corded Phone
Hipanasonic KX T7625 answering machine
It does not, but there is one available for the TDA or NCP system. It may already be there. It would be a smaller blue/black cabinet marked TVA-50 or TVA-200, or possibly a white box marded TVS if you are in the U.S.
There is also an SVM (Simplified Voice Mail) or an ESVM solution available for the TDA series.
Access codes by default are 165 and 500.
Carl
Dec 14, 2009 | Panasonic KX-T7625 Corded Phone
Panasonic KXT7630 has lost voicemail How do we reinstall? When we press the message button all we hear is dial tone
We tend to install Voice Mail as extension 165 or 500. What happens when you dial that on the intercom? If nothing, check the voice mail unit in the back room. It will probably be a smaller black and blue box with the TVA-50 in silver on the cover. It should have a single solid green light if it is synchronized with the phone system. If it is, then you can try to find out where it's connected to the system. It can be any digital port, so look for a missing number in your numbering plan like 112 or 120 on a TDA-50 or 115,116 on a TDA-100.
You may be able to check the button by pressing PROGRAM and the button and read the display. I'm not 100% positive that it will work on a fixed button (it used to work on a 74xx set where you could remap the button) but it might give you an indication if it got reprogrammed.
Carl
Dec 08, 2009 | Panasonic KX-T7630 Corded Phone
Need to change the main greeting in the company voice mail
The voice mail comes from an external box to the TD phone system cabinet. If it's Panasonic branded, it could be any one of several models designed to work on the TD product. The white boxes are TVS models in the U.S. (50,80,90,100,125,225 etc) the blue/black boxes are the newer TVA models (50,200). Each VM has the abillity for at least 100 "custom" greetings and, in some cases 32 company greetings. We use specific custom menus in the TVS product, but not in the TVA product because a TVA is set up visually.
Both models record and change greetings from mailbox 998, the message manager's mailbox. Once you get there, you choose option 5 then some other number like 4 for custom greetings and change the greeting (1-100) by following the prompts. Which one and how you get there is a lot easier if you have a manual.
So, since it's beyond the scope of a free forum, and you didn't post which VM you have, either consult your installer, manual, or comment back with your VM model number and I can give you a link to a manual.
If you absolutely want to do this yourself, you will need a computer with a serial port and a terminal program to access the TVS systems, or a USB port and maintenance software for a TVA.
Carl
Oct 29, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
297 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
