Question about Frigidaire ATF6000ES Front Load Washer
Washer GLTF2070DS0 I need to know if I have warranty with the frigidaiire comp. my washer is only 3 years old and has a terrible sound looks like the drum is wroken
  • noglesby08 Jun 22, 2008
    The LCD lights to my washer stopped working, although the washer itself still works. So I don't know what cycle the washer is using--hot, warm or cold! Help!
Water will not quit running in and overfilling
Posted on Feb 04, 2009
    Genius:
  • 1,028 Answers
Warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Posted on Jun 22, 2008
My Juki HZL F300 bobbin case is making a terrible noise. It sounds like the bobbin is going to spin right out of it. This noise is SO loud! Do I need to oil anything? It is not even a year old.
Try installing a brand new needle. Sometimes a bent or dull needle will cause lots of racket.
You should consult your owner's manual for maintenance--cleaning and oiling instructions. Most sewing machines do require oil--some more frequently than others. Most machines also need frequent oiling in the bobbin/hook area. Be sure to use only good quality sewing machine oil for your machine--NO 3-in-1, WD-40, cooking oil, or old brown stinky oil.
If it continues to make the noise, you should probably have it serviced. Since it is less than a year old, it might still be covered under warranty, so don't delay.
May 31, 2016 | Juki Sewing Machines
How do I fix the tub in the washer that has come loose and makes a terrible noise while spinning?
Hi if your tub as come loose I would find that very unusual if the washer is a few years old & used a lot you will probably find that the bearing have broken down it will sound like a grating noise & you will be able to lift the front of the drum if you google change bearings on your model of washer there should be guides out there my washer is on its third lot now 8 years old hope this helps you
Feb 08, 2015 | Washing Machines
Power Washer
See link for parts.
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Mar 31, 2014 | Garden
I'm not sure, but apparently controls to 3 year old washer shorted out? I'm handy, so is this something I can fix myself?
do you stiil have owners manual,,,go to warranty page i believe your under warranty for 3-5 years so if its the control you will get it for free...now since your handy just go to back of unit ,,please unplug first and remove scerws to top...remove your dispenser all the way out ...looking down frm open top of unit remove the bracket scews and the plastic console srews ..4 screws...now look down inside the bacck of console you have 2 more screws ,,,good almost there...look in the dispenser port ,,you will see 2 more screws ..threr you go its off..screws can be removed with a 1/4 nut driver...for warranty go to service matters.com...or call 1800 462 9267..good luck and if needed repost
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Tub bearing is making grining noise
yes when the washer sounds like an airplane taking off during the spin cycle, it is a worn rear bearing.
it does happen from the wrong type of soap being used. the suds from regular soap will destroy the seal and allow water to get into the rear bearings causing the bearing to fail and become noisy.
HE type soaps have been recommended by the manufacturer for about 6-7 years now and you MUST use them to prevent this from happening. it can also happen with HE is you just use too much.
now the good news... the inner tub has a lifetime warranty but the outertub, comes with seals and bearings, may only have a 5 year part only warranty.
what you can do is to call frigidaire at the 800# and ask if they can check the warranty for you. a 3 year old and a 5 year old unit might be covered by a part warranty. if so then the labor to replace the tubs will be about 200-300 bucks. i know its a pricey repair but is certainly cheaper then buying a new washer.
by the way, all front load washers will do this if you use the wrong soap.
Dec 30, 2008 | Frigidaire GLTR1670A Front Load Washer
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Vertical red line in display
I had a similar problem with a flat screen lcd for my desktop comp, and it turned out that I needed a new screen if i wanted to get rid of it, but it doesnt really cause much of a problem, so i didnt bother replacing it. If your laptop is still under warranty, (i dont know how long your warranty lasts) I'd look into getting it replaced if it really bothers you. But yes, its definitly the screen.
Aug 08, 2008 | Dell Latitude D505 Notebook
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
182 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
