Question about Keyspan USB Server US-4A (d47710) Print Server
US-4A Keyspan USB Server
Will the scan and print functions on an HP Laserjet 3050 work with this?
    Genius:
  • 2,035 Answers
This is not compatible with this printer the compatible list is :
compatible HP Jetdirect external USB print servers (HP Jetdirect en3700 Fast Ethernet Print Server, HP Jetdirect ew2400 802.11g Wireless Print Server; Print only solution; No support for printer's embedded Web server, fax or scan solutions): Microsoft® Windows® NT 4.0, 98, Me, 2000, XP Home, XP Professional, XP Professional x64, Server 2003; Novell NetWare NDPS services via TCP/IP only on 3.2, 4.2, 5.x, 6.x; HP Gateway (TCP/IP raw only) and Novell LPD gateway; Mac OS X v 10.28 and higher; Bonjour discovery supported; Red Hat Linux 6.x and higher; SuSE Linux 6.x and higher; HP-UX 10.20, 11.x; Solaris 2.5x, 2.6, 7, 8, 9, 10 (SPARC systems only); IBM AIX 3.2.5 and higher; MPE-iX; Citrix MetaFrame; Microsoft® Windows® Terminal Services
Posted on Jun 21, 2008
    Sergeant:
  • 260 Answers
Your USB server should work with any USB printer or scanner.
    Guru:
  • 1,894 Answers
If urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
  • 1 more comment
  • dewan nafees ahmed Jun 21, 2008
    yes sir.
    this must work.
    except audio and video USB devices u can use all kinds of devices with a USB function.
    u must be able to do it.
    dont forget to accept the solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon.
    found that the unit would experience problems if I submitted a print job
    greater than 7 MB through the KeySpan.
    resetting the printer and nothing wil get fixed.
    Only when u power cycled the KeySpan the things start work again.
    also
    . In some parts of its web site, KeySpan advertises that this unit
    supports USB v2.0, but if you read the fine print it's supporting at
    USB v1.1 speeds.
    This unit is really meant for multi-function printers
    so the fact is.
    u can do the print and scan functions. provided its of less size.
    thats it u need to take care off.
    thank you
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
How do I reset my keyspan Ps-4A print server?
Unplug power,
Pin in reset hole, hold in for 20 seconds
release and restart.
regards
dean
May 21, 2012 | Keyspan Computers & Internet
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
3. select compatibility tab choose your o/s
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Windows could not load the installer for NHCI. My printer is visible on the Keyspan server but I cannot print to it.
go to device manager and find the kepsan server, right click on the keyspan server with the yellow exclamation mark and say update driver, allow access to internet and it should install the driver...worked for me
Sep 01, 2010 | Keyspan USB Server US-4A (d47710) Print...
I cannot find a driver or SW package for Windows 7.
Tripplite bought Keyspan and are no longer supporting it. there are no 64bit drivers.
May 15, 2010 | Keyspan USB Server US-4A (d47710) Print...
I have the same problem. This is what Tripp Lite told me: "We have tested the existing drivers for the US-4A on both Windows 7 and Mac OS 10.6.2. Neither Windows7 nor Mac OS 10.6.2 functioned with the USB server products (US-4A and U2S-2A) while utilizing current drivers. I suspect that this is due to the fact that both OS' appear to have undertaken a major overhaul over their prior counterparts (XP, Vista, 10.5.X). In order for functionality to exist between the operating systems (in this case Win 7 and Mac OS 10.6.X) new drivers would need to be released. At this point, there is no plan to move forward with drivers to accommodate these operating systems."
I told them I was not impressed and that this lack of support would affect any future purchases of thier products.
Mar 27, 2010 | Keyspan USB Server US-4A (d47710) Print...
Hello, my Keyspan USB Server US-4A dont work with windows7, have a solution?
Until somebody writes a 64bit driver you are out of luck. Tripplite bought Keyspan and are not supporting the server.
Jan 29, 2010 | Keyspan USB Server US-4A (d47710) Print...
Can not connect my US-4A on my network.
Hello, I finally solved my problem by reset the device.
Oct 16, 2009 | Keyspan USB Server US-4A (d47710) Print...
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
Keyspan USB Server US-4A (d47710) Print Server Logo
620 people viewed this question
Top Keyspan Computers & Internet Experts
David Payne
David Payne
Are you a Keyspan Computer and Internet Expert? Answer questions, earn points and help others
