Question about Dell E173FP 17" LCD Monitor
Xenon LCD monitor will not turn on..
The monitor will not turn on.. I check the power from power supply cord its good. Any suggestion?
Thx
tengo un xenon 1810 e prende la lus del monitor pero la pantalla no
  • gooface Nov 16, 2008
    Mine the same thing! went to turn it on one day and nothing. No lights nothing. I checked the power cord and took it apart and checked power getting to the inside of the monitor. It does have power. Any suggestions?
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
Time for a replacement with the amount of data supllied, also see if the light indicator button comes on, if there is power, then check the video plug and card, do another video card and see if that corrects the problem.
Posted on Jun 21, 2008
Tengo problemas con la resolucion del monitor, me da 640 por 480 y 4 bits de calidad de color sin posibiladades de cambiarla, he formateado desde entonces salio el problema, me falta un driver pero no...
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG Flatron 575LM (White) 15.1 in. Flat...
Tengo un Polaroid FLM-4034B y tengo el power supply malo, me gustaria que me dijeras donde lo puedo conseguir y cuanto posria costar???
Revisa este enlace para encontrar la fuente de alimentacion para tu LCD.
Asegurate que la fuente es la misma que tu LCD esta usando antes de ordenarla.
Sep 28, 2010 | Polaroid FLM-4034B 40 in. LCD HDTV
Cuando enciendo el monitor tarda un minuto en restablecerse,
Would you please give information as regards the problem posted in English? Giving me this information in English will guide me to suggest a solution to the problem.
Take care.
Jul 16, 2010 | Acer AL1916W 19" LCD Monitor
Hola, tengo un monitor LG1515S Pero porque no puedo escuchar Ningún sonido, es que no tiene incorporado bocinas?
Hola, este monito no trae bocinas incorporadas, lo siento.
Fosg2000, por favor califica mi repuesta
Mar 16, 2010 | LG Flatron L1515S 15" LCD Monitor
Buens noches..tengo un monitor DELL2005FPW 20.1
Creo que tienen capas superpuestas de la misma imagen en su monitor. Prueba a revisar los cables doblados o dañados. Ver si hay dispositivos electromagnéticos cerca del monitor. Por una vez, intenta huir de la liberación de la energía de la pantalla. Para ello, desconecte el cable de alimentación del monitor y presione el botón de encendido en el monitor durante unos 15 segundos. Usted puede también intentar el control de la imagen en modo seguro de "Windows". si la imagen está muy bien allí, es necesario volver a instalar / actualizar los controladores de vídeo.
ENGLISH: I think you are having overlapping layers of same image on your monitor. Try checking the cables for bent or damaged pins. See if there are any electromagnetic devices near the monitor. For once, try releasing the flee power from the monitor. To do this, unplug the power cord of the monitor and press the power button on the monitor for about 15 seconds. You can also try checking the image in safemode of "Windows". if the image is fine there, you need to reinstall/update your video drivers.
Oct 15, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Need one 12v 2500mah power cord for flat screen monitor xenon is the brand name and is prob kinda old cheap if possible
I had a similar problem. Here is what I did:
I went to the computer store and I did purchased a generic Laptop power supply that provides 13 Volts @ 2Ah. y display was working fine with it.
You may be able to take the display information (Voltage, amperage, connector size, positive and negative information) and get assistance from a computer store (maybe radio shack, circuit cit... oops, they closed stores, never mind that one. Best buy or any electronic store in your area).
If that doesn't work or you can't get a similar power supply, you can check in e-bay and get one similar like this one:
http://cgi.ebay.com/12V-DC-Power-Supply-4-Amp-12-Volt-Adapter-LCD-CB-4A-HP_W0QQitemZ380155972539QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item58830fcbbb&_trksid=p3286.c0.m14
but you need to be sure about the positive and negative connector.
Good luck.
Sep 08, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
No sign of power
have the switching power supply checked or might need a replacement
Aug 10, 2009 | Gateway 19" Flat Panel LCD Monitor
do u check monitor on/off button lies on monitor bottom,, if it is on than check from menu button whether brightness option is well set.
Feb 25, 2008 | Xenon XEN 1510P (White) 15 in. Flat Panel...
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
Alun Cox
