The picture is not clear - Televison & Video
  • 927 Answers
Good Day por24;
The most common concern with rear projection TV's that have pictures that are not clear is that the lenses and mirror needs to be cleaned. Most manufactures allow access to this area, lenses&mirror, from the front of the TV by removing the screen ***'y. That is the easiest way but not always the most obvious.
If the the brand is Phillips/Magnavox the problem will more than likely be contamination of the CRT's fluid,Ethylene Glycol, in which will have to replaced.
If not clear meaning the colors are seperated then the TV will be experienceing a convergence problem.
Good Luck, hope this was helpful, if not rtn with brand an model number, Big Irish.
Posted on Jun 21, 2008
I have an android lg MS 500and I have a couple videos and couple pictures that are very blurryI even paid to have them cleared upand it didn't work because my money and runso could you please help meget...
If the pictures are blurry, there's really little you can do to make them clear. The information you would need to have to sharpen them up simply is not there. You would need to take the pictures again.
Nov 04, 2014 | Cell Phones
How do I clear the pictures from my memory card? When I transferred the pic to my computer it asked if I wanted to clear the card but I wanter to be certain they were, in fact, transferred before I...
You can clear ALL pictures from the card by formatting it. In fact, the memory card should be formatted EVERY time you finish downloading pictures from it. This will prevent later problems.
To format the card in the L20, press the MENU button, select Setup (the wrench icon), then select "Format card" (the memory card icon).
Jan 13, 2011 | Nikon COOLPIX L20 Digital Camera
My picture is not cystal clear. Do I need a Hdmi cable with this tv or some kind of cable for a clear picture?
All HD televisions need HDMI cables for clear picture. If you don't have one, you're not utilizing HD. Opt-World has some good, low priced cables for HDMI.
Dec 01, 2010 | Element Electronics Televison & Video
My picture isnt clear. whats the best color setup?
The best way to clear the picture on these sets is to remove the screen and clean the mirrors. If it is still not clear after that it may be a bad lamp or failing capacitors in the chassis. They cause wavy lines and makes the picture blurry.
Jan 31, 2010 | Mitsubishi WD-62525 62" Rear Projection...
It does not shows clear picture
turn the black ring that is around the len's while your cam is on and you can see a picture. ...the black ring will focus your lens. turn till you get a clear picture...turn either one way or the other till picture clears up
Aug 30, 2009 | HP USB Web Camera
All pictures which i open using internet are not clear.
Go to your Browser Tools>> Internet Options Go under the Tab that says Advanced Scroll down to almost at the bottom under Multimedia Tick everything under the Multimedia Tab and hit Apply
Jun 02, 2009 | Toshiba Satellite L305-S5907 Laptop
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Can`t get clear picture anymore
Hello dhack56,
Can you post a picture of the screen as the TV is playing, this way I can see if the picture is fuzzy, or if the images are split, all of which classify as not a clear picture. A picture of the screen will help with the diagnosis.
Thank you,
Shuttle83
Oct 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
CLEAR PICTURES OFF DISC
Select a picture (pres rev button)
Then press the Del button twice.
The display gives you the option to delete all the pictures or multiple pictures.
Hank
Apr 22, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
