Question about Breadman TR444 Bread Maker
Bread sticks to the pan
I just used this item for the first time and the bread stuck very badly so that I had to break it out and the bottom of the bread completely separated....this item was given to me by someone who used it only once before.
  • Anonymous Jun 24, 2008
    I just got the breadman TR444 secondhand and had the exact same problem. Very disappointing, especially since I could tell the bread was so good. I had to eat it in chunks.
Check the pan and see if it needs to be replaced. if it is scratched and worn the teflon coating isn't working properly
Posted on Jan 12, 2009
Bread sticks to the pan and the dough blade what am I doing wrong
It is not uncommon for the paddle to get stuck in the bread loaf especially with thick crust breads (i.e. french) Be sure to choose light crust and sometime using milk instead of water help too.
Feb 08, 2013 | Kitchen Appliances - Others
I have a Sunbeam Convection Bakehouse model BM005 and the bread pan sticks all the time so badly that is it impossible to get the loaf out without mutilating it. What can I do?
We have one and used it for years. What we found works is to take the kneading plate out before it starts cooking. Do this after the beeps to let you know when to add fruit, and the kneading has finished.
This also saves bread as you do not loose a bug chunk in the bottom. Our pan is not very good any more, but we can still get the loaf out without any problems. Just need to let it cool for about 10 minutes out of the machine before attempting to take the loaf out if it is stuck.
Nov 24, 2010 | Sunbeam Kitchen Appliances - Others
Bread sticks to the bread pan, Can't get it out of the pan when finished. Can I buy a new pan?
Unless the non-stick surface is worn off your bread should not be sticking. When it's done do you turn the pan upside and shake vigoroursly up and down and side to side over the countertop? It should start to slide out. I have owned over a dozen different machines and I have never had the bread stick in any of them. It is best to try to remove the bread right after it has baked and use hot pads or hot pad gloves are best. If it is really stubborn try turning the little "T" on the bottom back and forth. Eventually your bread should come out if you stay with it. Shake!, shake! shake!
Oct 29, 2010 | Toastmaster 1142 Bread Maker
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Bread stick in pan
I have the same problem too, I just use a plastic or silicone spatula, the kind that you use to scrape the cake mixture off the sides of the bowl, just use the thinnest one you can, I also try to loosen the bread loaf by moving the part that moves the blades, just move it a little, back and forth and try to shake your loaf out. I hope this works.
Jul 02, 2009 | Toastmaster 1193 Bread Maker
Bread sticks to pan and crust always burnt
My wife grinds her own wheat, and bakes her own bread. She suggests using less sugar. You also could try switching to honey if using white sugar. Too much sugar/honey will cause over browning and sticking.
If problem persists post back.
Sep 25, 2008 | Toastmaster 1193 Bread Maker
Can't remove the bread pan
The same thing happened to me yesterday. I made my first loaf and then I couldn't get the bread pan out. We kept pulling and yanking on the bread pan until it felt like it was going to break! This morning, my husband called Cuisinart. The man on the phone said he has the same machine at home, and that you just have to pull it really hard. He said don't worry, it won't break, just pull it. My husband pulled it again and it came out. I guess he just got the right angle on it.
It was definitely stuck from the bottom, not from the side clamp things. The man on the phone at Cuisinart said that after you use it more, it becomes easier to remove the bread pan. We put the bread pan in and then pulled it out a few times, and it seems like now it comes out easily, the way it should.
I felt obliged to respond here, because I was very discouraged after reading this thread last night. I was about to return the machine. I hope this solution helps.
By the way, my first loaf yesterday was the Rosemary Bread from the cookbook that comes with the machine. It was AMAZING.
Sep 10, 2008 | Cuisinart CBK-200 Bread Maker
Bread sticks to pan
May be that the coating on the pan is just wearing off. Had the same problem several years ago and it was just that the poor old machine was over used and the simplest solution was to buy a new pan. That machine went though 2 of them before it died its self.
- Neil
May 25, 2008 | Breadman TR444 Bread Maker
Dough blade sticks in bread
Dunno - I've got the same problem. A few things do help: 1. Scrub the pan THOROUGHLY before baking new bread. Especially around the paddle, where little bits of baked dough can collect. 2. Put in a little more butter or oil or shortening than the recipe calls for. Just a scoche.  3. Put the bread up before going to sleep, and take out in the morning. That seems to allow enough time to elapse that the bread comes out without taking a chunk out of the bottom. I also tried putting the pan in wet from a washing, instead of waiting for it to dry. This morning's loaf came out fine & dandy. I don't think anything's going to stop us poor 3400 owners from having to bang the bread pan upside down on a cutting board in order to get the bread out of the pan. Sigh.
Hope this all helped. Amy
Dec 21, 2007 | Welbilt ABMIL2P Bread Maker
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Breadman TR444 Bread Maker Logo
165 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
