These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the
steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug) Rear Right speaker -: Blue w/White stripe Rear Left speaker -: Brown w/Yellow stripe Front Right +: Purple Front Left +: Dark Green Rear Right speaker +: Blue w/Orange Stripe Rear Left speaker +: Brown w/Blue Stripe Power Antenna/Amp: White (Gray Plug) +12v battery wire: Pink or Pink w/White Stripe +12v Ignition wire: Red w/ White Stripe Front Right speaker -: Blue w/ Red Stripe Front Left speaker -: Brown w/ Red Stripe
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe Car Radio Ground Wire = Black Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe Car Radio Dimmer Wire = Light Blue w/ Red Stripe Car Radio Illumination Wire = Orange w/ Black Stripe ?? Don't know ?? Red Wire (No power to wire Constant or Accessory) Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front: White w/ Green Stripe (+) Brown (no stripe) (-)
Right Rear: Purple w/ White Stripe (+) Light Blue (no stripe) (-)
Left Front: Light Green (no stripe) (+) White w/ Orange Stripe (-)
Left Rear: Light Blue w/ Black Stripe (+) Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front: White w/ Green Stripe (+) Green w/ Orange Stripe (-)
Right Rear: Orange w/ Red Stripe (+) Black w/ White Stripe (-)
Left Front: Orange w/ Green Stripe (+) Blue w/ White Stripe (-)
Left Rear: Red w/ Green Stripe (+) Red w/ Blue Stripe (-)
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note: using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Battery
White/Yellow Stripe or White/Blue Stripe
Accessory
Yellow/Red Stripe
Ground
Black
Illumination
Red
Dimmer
Red/Black Stripe
Power Antenna
Yellow/White Stripe
Left Front Speaker (+)
Blue/Green Stripe
Left Front Speaker (-)
Gray/Black Stripe
Right Front Speaker (+)
Red/Green Stripe
Right Front Speaker (-)
Brown/Black Stripe
Left Rear Speaker (+)
Blue/Yellow Stripe
Left Rear Speaker (-)
Gray/White Stripe
Right Rear Speaker (+)
Red/Yellow Stripe
Right Rear Speaker (-)
Brown/White Stripe
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10.
If you DID..... well.....
we have a LOT of work to do....
