Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker not working
I opened the freezer and found water had leek down the back side of the ice maker. I took out the tube from the back of the unit and cleaned out all the ice that had frozen out side of the ice maker. Once I put back the water line to the freezer I got water out of the door but water does not go into the ice tray.
any thoughts
    Problem Solver:
Had a similar problem, the water filter in fridge was plugged, put in new one and ice maker started working again.
Posted on Jun 28, 2008
    Problem Solver:
  • 27 Answers
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Posted on Jun 21, 2008
Have replaced the 3part inlet water valve for our fridge freezer. Water is working fine,but still not making ice.
Check the ice bin level arm (also the ice maker on/off switch) is in the down position. It senses when the ice bin is full and turns off the ice maker until some ice in the bin gets used. It can also be lifted into the up position to turn the ice maker off.
Mar 07, 2017 | Westinghouse Refrigerators
My ice maker is not working when water goes in to fill it up..its going all over freezer on to the floor
There is a tube in the back of the freezer where the water comes in and then filters down into the ice maker. This is a simple task. What we need to do is check this tube and surrounding area.
Is there a tube in the back for the water to flow into the ice maker? If not the water will most definitely spew and run everywhere.
If there is a tube, does it have a hole? Does it have ice in it? If so we need to free the tube of the obstruction or replace the tube.
If the water is coming down the tube into the ice maker, how is it escaping the ice maker? The tube rests in a cup that the water drains downwards slowly filling up the ice tray. We need to inspect this area for anything that may leak water.
These scenarios should cover the basics plus extra. If you need further help let me know, but this should get the problem figured out :) good luck!
May 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag Icemaker freezing up
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
 You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
Aug 31, 2009 | Maytag Freezers
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice is forming on my "not working" ice maker drawer
check that the water isn't over filling the ice mould or that water isn't escapeing down the back of the draw due to an allignment issue with the filler tube. worst case could possibly be a cracked ice mould.
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool GS6SHAXML side by side refrigerator not making uce
check the filkl tube it may be frozen up due to a leaking solinoid valve.
Apr 06, 2009 | Whirlpool ED0GTQXMQ Side by Side...
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
