Question about Panasonic PT-56TW53 56" Rear Projection Television
Double images Green converge seems to be way off. Worked fine last night Unable to adj. Also pic is bent inward on right side.
  • jerome21 Jun 24, 2008
    How do I disconnect the the kft7aa334fi...there is one thick red cable, and one thin one...it is the only thing holding my card in
  • Panasonic Master
  • 8,617 Answers
Change the convergence ICs STK392-110 replace both you can get replacements at the following link and they provide free instalation instructions with pictures I suggest getting a couple of the convergence Resistors as well. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 21, 2008
  • Sonny Berry
    Sonny Berry Jun 24, 2008
    Slide the rubber boot off at the point where the Red HV cable enters the splitter ( $ large red wires) and then grasp the wire firmly with a pair of pliers with tape on the jaws to protect the wire then with a twisting motion pull the wire out. The small wire un plugs from the small focus block at the oter end it just un plugs.
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Panasonic PT-56TW53 56" Rear Projection Television Logo
170 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
