Question about Logitech LX 300 Keyboard/Mouse
MY CAPS LOCK IS STUCK, AND WILLNOT GO BACK TO REGULAR
6/20/08
PLEASE HELP ME. I AM STUCK ON CAPS LOCK AND I EILLNOT GO BACK TO REGULAR TYPING.
WHEN ACTIVATED, THE CAPS LOCK SIN WILL SHOW ON MY SCREEN BUT I CANNOT MAKE IT GO BACK.
THANK YOU IN ADVANCE
CT
Just had this happen on a K800 wireless keyboard. Went into keyboard settings and *enabled* the caps lock key, turned off caps lock, then *disabled* the caps lock key again. Hope it helps
Posted on Oct 07, 2011
  • Johann Bark
    Johann Bark May 14, 2014
    Worked for me (K750, Windows7). To find the keyboard settings: a) windows start button, b) typed "keyboard", then clicked on "Mouse and Keyboard", c) clicked my keyboard, d) unclicked disable caps lock key.
CAPS LOCK DOESNT UNLOCK
if you hold down the Shift key and type are the letters small??
sounds like your Caps Lock key is stuck
Nov 02, 2017 | Computers & Internet
Ipad CAPS LOCK IS STUCK
Capslock on the iPad is done by double-clicking the upper-case button. Double click it again to bring it back to regular lower-case. If not, restart the iPad.
Feb 25, 2014 | Apple Air Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
Oct 08, 2008 | Dell INSPIRON 6000 CENTRINO...
Problem with sony vaio keyboard
Sounds like you've got something stuck under your shift key. Carefully clean out under the keys, try a paintbrush and a hoover (on low suction if possible).
Be careful not to knock any of the keys off. They're held on by small clips which pop out or break easily.
Aug 22, 2008 | Sony Computers & Internet
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
Open Questions:
Logitech LX 300 Keyboard/Mouse Logo
5,992 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
