Question about Logitech Harmony 880 LCD Remote Control
Harmony 880 doesnt work on devices
The remote does not respond even though i programmed it and made it learn all of my ir signals it does not work on any devices i can navigate though the remote though. it just wont cooperate with my devices
  • 2 more comments
  • drose12334 Nov 29, 2008
    I have the same exact problem...
  • jalmadar Dec 29, 2008
    Same problem...
  • Anonymous Jan 11, 2009
    same problem,. trying to disable firewall and new usb cord - will see if this resolves.
  • ErikEarl67 Mar 10, 2009
    My harmony 880 stopped controling devices last week. It stopped mid command. truned off half the devices and that was that. I reloaded the firmware but that did not change anything. I checked the IR lights like the online tech support said and they come on but do not flash.
I did some more searching and it sounds like the IR emitters die. People see to have sucess with replacing the emitters with new or ones from an old remote. I will find out :)
http://forums.logitech.com/logitech/board/message?board.id=remote_hardware&thread.id=724&view=by_date_ascending&page=2
Posted on Mar 10, 2009
Our devices suddenly stopped responding to the logitech signals.
If you removed the battery, you may have to reprogram it. will need the make and model number off the bottom of the remote, and what you want to program it to, (TV,--VCR,etc)...hope this was helpful..
Jun 02, 2010 | Logitech Harmony 880 LCD Remote Control
Tip
Replacing Logitech Harmony 880 IR LEDs
I've written a nice guide with pictures on how to replace the IR LEDs in a Logitech Harmony 880 Remote Control.
Link
on Sep 08, 2009 | Logitech Harmony 880 LCD Remote Control
All of sudden the harmony remote does not work the infred but i dug out the other remotes and they still work
If your remote is programmed correctly but no longer controls any of your devices, then most likely your LED IR emitters have burned out. There is an Ebay-hosted service that fixes this problem for $14.00. You can find it here: http://cgi.ebay.com/We-can-Repair-your-Harmony-880-Remote_W0QQitemZ200437939363QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eab083ca3
Feb 17, 2010 | Logitech Harmony 880 Universal Remote...
I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
Feb 08, 2010 | Logitech Harmony 890 LCD Remote Control
My Harmony 880 remote stopped working where can i get it repaired
It all depends on what your specific problem is. Logitech will not repair remotes once they are out of warranty. However, you can find lots of guidance on the web to assist you with the most common issues that affect the Harmony 880/890 series. If your remote is programmed correctly but no longer controls any of your devices, then most likely your LED IR emitters have burned out. There is an Ebay-hosted service that fixes this problem for $14.00. You can find it here: http://cgi.ebay.com/We-can-Repair-your-Harmony-880-Remote_W0QQitemZ200437939363QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eab083ca3
Dec 15, 2009 | Logitech Harmony 880 Universal Remote...
Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
Harmony 890 channels and volume wont work
Sometimes you need to go into the menu page for the device that doesn't work and you need to "learn" the keys to the new remote. "Learn" meaning pressing the buttons on your original remote with the Infrared part of the remote facing the Infrared part of the new remote. This will help the Harmony remote duplicate the signal to the device you want to operate.
Apr 09, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
418 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
