Try digital camera video recovery program. it can help you recover damaged video from digital camcorder.
Take so called data recovery program to handle the issue and see if you can grab some or all of the files back. you may have a try Wondershare Photo Recovery (also recover videos and music under both Windows and Mac OS).
Photo Video Recovery (if you are running Windows OS)
Mac Photo Video Recovery (for Apple Mac OS X)
You should take care - before your files are recovered, do not save more files to the device concerned(do not take more videos or photos) in case overwritten situation will happen.
SOURCE: video management problem
sounds like you need to "recover" the hard drive.
Only other option you can try is to reset the camera.
SOURCE: JVC G-z-mg365bu video management file is broken
For broken files, everio will prompt you to recover once switched on. If you mean deleted by accident, you can use file recovery software like Final Data Enterprise and a lot more. Mostly can be recovered, sometimes 80% or 90% of your total recording. Good Luck
SOURCE: warning-- video management file is broken---
okay, try to format your hard drive, if unable to you will need to replace with identical zif HD, see youtube demo how to replace the hard drive, very easy but must be very careful, format after replacing.
The Recovery Manager program makes it possible to restore your laptop to its settings as of a previous date or restore your computer to its original factory settings, which will erase all of your installed programs and personal data. Using the recovery partition allows you to bypass the hassle of keeping track of recovery discs, which could be damaged in storage, rendering them useless when you need them.
Instructions
