Question about Epson EMP 720 Multimedia Projector
Warning lights Hi, when I turn on my EMP 720 the green warm up light flashes as normal, but then the red, 1 second flash warning light comes on, I have checked and cleaned the dust filters and also checked the bulb which seems to be fine, any idea, regards peter
  • Anonymous Jun 21, 2008
    ja imam isto Espon projektor ali je slika slaba samo kasno navečer mogu pogledat i nikako drugačije
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Posted on Oct 06, 2008
    Scholar:
  • 40 Answers
If the light is blinking red rapidly, there is a problem with the lamp. If the light is blinking red slowly, there is a problem with the projector. If the light is red and not blinking, the projector is overheating, which turns the projection lamp off automatically. Let the projector cool for a few minutes, then turn it back on. Make sure nothing is blocking the ventilation vents. Check to see if the air filter is clogged. If it is, clean the filter by following the steps in your User's Guide. Let the projector cool for a while after cleaning the air filter. If the projector continues to overheat after you clean the air filter, the problem may be caused by damage to the cooling fan or internal circuits. Please contact EPSON technical support for assistance with the error, or take the projector to an authorized Epson service center.
Posted on Jun 24, 2008
Mk1 golf gti 1.8 oil red warning light comes on when engine is warm
You need to check for tow things first check oil level and its reapilty second you need to check oil volve and oil pump
Jan 16, 2013 | Cars & Trucks
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
I have an Epson EMP TW10. I have replaced the lamp but it will not illuminate. The temperature warning light flashes red permanently after switch on.
Hi
Can you check the filter for the projector, looks like a screen underneath or on sides, open and clean it up.
Hope this helps
Mar 26, 2010 | Epson EMP-TW10H Multimedia Projector
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Projector epson emp-30 in error
i have one that work but there are red bars on the display, for sale 50.00 no lamp
Mar 22, 2009 | Epson EMP 30 Multimedia Projector
Ps3 when turning on green light yellow light flashes red then turns off
this is known as yellow light of death u could call sony for a repair which cost 150$ or fix it yourselve with a video on youtube.
Warning first option means u lose your data
Warning second option requires a skilled craftsman
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Apr 15, 2008 | Epson EMP-54 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Nov 24, 2007 | Epson EMP-S1H Multimedia Projector
Red warning light does not go off
use the end of a turkey baster to push water through the hole in your water bucket....do this a few times while having the hot water nozzle on. This fixes it for me.
Oct 17, 2006 | Saeco Vienna Espresso Machine
Epson EMP 720 Multimedia Projector Logo
581 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
