Question about Sony RMT-V202 Remote Control
Need to unlock my tv
I got a AVOL model #: ACT21HN02
manufactored: May 2007
S/N:21CT070500660
20 V NTSC/ATSC CTV
I accidentally lock my tv. It has a red lock symbol on the bottom of the screen every time a turn it on. I don't know how to unlocked it, please help!!!! I have search every ware for the codes but it has been fruitless.
my email is: anij80@hotmail.com or vegita6879@yahoo.com
  • anij80 Jun 21, 2008
    I dont have a ent button on the control. All i have is a vchip button, AV,PP,Sleep,display review and zoom
    S/N:21CT070500660
    20 V NTSC/ATSC CTV
    My control is the one that came with the TV. The only button available in the control are these: Mute, power, AV,PP,Menu,VCHIP,Sleep,Display,Review and zoom, and off course the numbers and vol buttons.
    Master:
  • 848 Answers
Better take your tv to service center .........since you have locked there might be some settings change so dont take risk by going for unlock code
Posted on Jun 21, 2008
  • Sony Master
  • 13,433 Answers
Is this problem solved? another solution has been accepted.
    Guru:
  • 1,894 Answers
Go to parental control and give the pass code
it wil get unlocked
  • dewan nafees ahmed Jun 21, 2008
    1. Turn on the component to be programmed.
    2. On the remote control, press and hold the S button.
    3. While holding the S button, press and release the POWER button
    4. Release the S button.
    5. Press and release the appropriate component button for the component being set up.
    6. Using the number pad, enter the component's manufacturer code.
    7. NOTE:
      If more than one code number is listed for the manufacturer, repeat the
      procedure, entering one code at a time until you find one that works.
    8. Press the ENT button.
    9. Point the remote control at the component.
    10. Press the POWER button to verify operation.
    dont forget to accept the solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon.
    The code for AVOL or type in AVL for a search it shows up as an APEX
    brand. Need to use the Apex code. 0156, 0748, 0765 0767, 0879. 0748
    worked for few people
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
Need a Remote control to lift CHILD LOCK
here is the link to avol's website, i would suggest sending a inquiry to them or check out thier support section of thier website http://avl21c.com/renewal/surpport_ServiceInstruction.htm
hope that helps
ryan
Mar 04, 2009 | Televison & Video
SWITCHING TV FROM NTSC TO ATSC USING THE REMOTE
I need the model # to make sure you have an ATSC or QUAM tuner?
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a tv made by AVOL Model # ACT21HN02, BUT I CANNOT FIND THE
most remotes have a code search function, you should be ably to find a code that works that way.
Dec 04, 2008 | Televison & Video
Do I have a ATSC tuner in my 2002 Quasar 27" TV?
NTSC is the (analog) standard passing into history in Feb. '09 and ATSC is the new digital standard being used afterward for over-the-air (reception by antenna) broadcasts. This changeover affects only the broadcast channels and if you have cable or satellite reception the changeover will happen whenever they find they can't charge their captive audience such a high premium for HD.
I found no evidence that your set is ATSC ready so if you are receiving your signal by antenna, you need to scurry about and buy a converter for your set. Make sure the one you buy is on the list of 'approved' models to which you can apply the $40 coupon(s).
Coupon & info site
Oct 05, 2008 | Quasar SP-2725 27" TV
Tv Tuners
Hey jp62388,
According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
http://www.dtv.gov/index.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Televison & Video
Rca g26261tn colortrak television
If the TV is HD then yes it is ATSC if it is HD ready Then it is NTSC if it is noe of the above then it is NTSC. The Advanced television standards committiee was developed in 1982 .
Mar 08, 2008 | RCA F32665 32" TV
Televison & Video Logo
445 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
