Question about Mitsubishi WS-65413 65" Rear Projection Television
Mitsubishi WS_65413 won't power up??
I have a WS-65413 Its about 5years old. I never had any problems until now. I was watching it and all of a sudden lots of hoizontial lines came across the screen about in the middle of the picture. After that it shut down. I turned it on and 3 seconds or so later it shut back off. I went to the backside of the television and smelled something burning. I uplugged it and removed the cover. what I found was The R5K02, R5K01, And the AG5K00 parts were burnt up.I don,t know if just replacing these will fix it ,or did something else fail that caused these to POP? I need some help or advise. Thanks Scott
  • DOBOYT May 02, 2009
    POWER SURGE ,TV WON'TCOME ON NOR WILL THE POWER SURGE PROTECTOR???????????????
  • 927 Answers
Good Day Scott;
When resistors and or fuses burn out, it's a sign that some other device was drawing too much current. So, replacing these parts alone will not repair the TV. There could be a couple of things that may have caused this condition. First, look toward the front of the chassis (from back) and look a shiny substance (fluid) on the circuit board. Look very closely! It may be your convergence circuit, most common, IS's. If you are not experienced in repairing TV's, I would call a factory authorized service dealer to have this unit repaired. It will take an expert to repair TV properly.
Sorry I could not give you good news, good luck; Big Irish.
Posted on Jun 21, 2008
  • Oscar0000 Mar 16, 2011
    what are the replacement parts for the three burned up parts (R5K02, R5K01, And the AG5K00 )???
Why won't TV won't stay powered on?
probably not worth it. How many times does the LED flash? That will indicate your failure cause. Problem is this is an old tv and parts are not available or cost effective. Unless its bad capacitors or bad solder you could be looking at rediculous amounts to fix it. Mitsubishi WS 65413 Manuals Support and Troubleshooting TVs
here is a link to the manual. please provide the amount of LED blinks. itll blink a few times and pause.
Feb 04, 2015 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65413 hdmi to component
unless you can find some kind of adapter--no. And for that matter the set has a HD input that is component----HDMI may use less cables but is prone to a lot of issues.
Apr 16, 2012 | Mitsubishi WS-65413 65" Rear Projection...
How do I take the ws-65413 cabinet apart
IF it can you will see on each side of the cabinet two plastic caps (fairly flat) If they are there they pop out and under each of the four caps a L bolt, rotate it to left and top half of set can be removed from bottom, IF NO CAPS ON BOTH SIDES, IT DOES NOT HAVE THAT FEATURE.
Nov 16, 2011 | Mitsubishi WS-65413 65" Rear Projection...
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
1080i
grab your TV remote and go to setup. check your input settigs and change them from RBG.
Aug 30, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65413
The industry uses PTS corporation for board repairs and exchanges. You should be able to find them on-line. You will need the part number off your circuit board to check their price list. They also have tech support but I don't know if it's available to just anyone.
Dec 31, 2007 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65413 65" Rear Projection Television Logo
325 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
