Question about 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch
How to configer vlan,and unit 1 or 2?? i config ip the switch but can't get the internet,
  • Anonymous Oct 14, 2008
    I have a switch 3com, when I want to take off to Internet, I can´t. I make this in
    device/ip route and I give Destination IP address 0.0.0.0 and mask 0.0.0.0 and
    Next Hop I give the Gateway that simule a router. What do I can?
  • 86 Answers
VLAN configuration is able to do in the layer 2 swicth.
Posted on Jul 09, 2008
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How do i configure the switch to allow web access through the serial port
If you can't find the manual on the Dell web site, there is a copy at: http://www.manualowl.com/m/Dell/PowerConnect-3548/Manual/188907
Did you use the command: ip http server ? See page 501 in the manual.
I would not recommend setting up a network switch with password-free access to the internet. You should at the very least limit access to a small subset of IP addresses (e.g. your network group's machines). The best practice is to use ssh communications or https with the web browser, otherwise anyone with a well-placed sniffer can read your clear-text traffic.
Sep 19, 2012 | Dell PowerConnect 3548
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
I need to config a hp procurve 2610 with a data and voice vlan to work with my mitel.
hostname "Switch1"
qos dscp-map 101110 priority 6
snmp-server community "public" Unrestricted
vlan 1
name "Data_Vlan"
untagged 1-28
ip address 192.9.180.19 255.255.255.0
exit
vlan 2
name "Voice_Vlan"
ip address 10.9.180.5 255.255.255.0
qos dscp 101110
tagged 1-28
voice
exit
Program the port that the PBX is in as a untagged port on Vlan 2
Nov 30, 2009 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
IP IOS Command not working with switch
you want to give IPs to your VLANs and also make physical interfaces members of a VLAN instead of giving IPs to physical interfaces
Mar 05, 2009 | Cisco Catalyst 2960 8-Port Ethernet Switch...
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Applying QOS to a VLAN on a procurve 2626
Need to config the diffserv you want to program
Example: config t=qos dscp-map 101110 priority 6
Need to set it to the Vlan
config t(vlan 101)= qos dscp 101110
ip address 192.168.101.2 255.255.255.0
qos dscp 101110
voice
exit
This a a common differ-serv 46 priority 6 for IP phone system
Dec 05, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Open Questions:
Random reboot of 3com 4400 stack Can you help, please? I have a 3Com 4400 stack running the latest version v6.13S. The stack sometimes reboots randomly. The logs showed the following: Unit 1 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 42 42 6.13s S/W Watchdog (r) 17 Hrs 42 Mins 52 Secs Uptime Hours 16828 Reset 41 43 43 6.13s S/W Watchdog (r) 0 Hrs 51 Mins 14 Secs Uptime Hours 16828 Reset 42 44 44 6.13s S/W Watchdog (r) 0 Hrs 47 Mins 54 Secs Uptime Hours 16828 Reset 43 45 45 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 15 Secs Uptime Hours 16828 Reset 44 46 46 6.13s S/W Watchdog (r) 0 Hrs 18 Mins 48 Secs Uptime Hours 16828 Reset 45 47 47 6.13s S/W Watchdog (r) 0 Hrs 33 Mins 59 Secs Uptime Hours 16828 Reset 46 48 48 6.13s S/W Watchdog (r) 1 Hrs 9 Mins 57 Secs Uptime Hours 16829 Reset 47 49 49 6.13s S/W Watchdog (r) 0 Hrs 59 Mins 28 Secs Uptime Hours 16829 Reset 48 50 50 6.13s S/W Watchdog (r) 0 Hrs 42 Mins 37 Secs Uptime Hours 16829 Reset 49 51 51 6.13s S/W Watchdog (r) 20 Hrs 17 Mins 57 Secs Uptime Hours 16849 Reset 50 52 52 6.13s S/W Watchdog (r) 0 Hrs 5 Mins 19 Secs Uptime Hours 16849 Reset 51 53 53 6.13s S/W Watchdog (r) 0 Hrs 55 Mins 15 Secs Uptime Hours 16849 Reset 52 54 54 6.13s S/W Watchdog (r) 0 Hrs 37 Mins 23 Secs Uptime Hours 16849 Reset 53 55 55 6.13s S/W Watchdog (r) 1 Hrs 26 Mins 17 Secs Uptime Hours 16850 Reset 54 56 56 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 12 Secs Uptime Hours 16851 Reset 55 57 57 6.13s S/W Watchdog (r) 17 Hrs 26 Mins 34 Secs Uptime Hours 16868 Reset 56 Assertions : Id S/W Rel File Name Line 5 3.00 agg_sma.c 1215 6 3.00 agg_sma.c 1215 7 3.00 agg_sma.c 1215 8 3.00 agg_sma.c 1215 9 3.00 agg_sma.c 1215 10 3.00 agg_sma.c 1215 14 3.00 agg_sma.c 1215 Last System Error Data: ID (57) S/W Rel (6.13s) Reason (S/W Watchdog) Unit 2 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 236 236 6.13s S/W Watchdog (r) 0 Hrs 10 Mins 55 Secs Uptime Hours 48145 Reset 235 237 237 6.13s S/W Watchdog (r) 2 Hrs 2 Mins 20 Secs Uptime Hours 48147 Reset 236 238 238 6.13s S/W Watchdog (r) 0 Hrs 29 Mins 15 Secs Uptime Hours 48147 Reset 237 239 239 6.13s Power (r) 2 Hrs 0 Mins 0 Secs Uptime Hours 48149 Reset 238 240 240 6.13s S/W Watchdog (r) 17 Hrs 5 Mins 9 Secs Uptime Hours 48166 Reset 239 241 241 6.13s S/W Watchdog (r) 2 Hrs 55 Mins 1 Secs Uptime Hours 48168 Reset 240 242 242 6.13s Power (r) 3 Hrs 0 Mins 0 Secs Uptime Hours 48171 Reset 241 243 243 6.13s S/W Watchdog (r) 91 Hrs 47 Mins 28 Secs Uptime Hours 48262 Reset 242 244 244 6.13s S/W Watchdog (r) 45 Hrs 25 Mins 25 Secs Uptime Hours 48307 Reset 243 245 245 6.13s S/W Watchdog (r) 4 Hrs 29 Mins 38 Secs Uptime Hours 48311 Reset 244 246 246 6.13s S/W Watchdog (r) 117 Hrs 3 Mins 10 Secs Uptime Hours 48428 Reset 245 247 247 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 9 Secs Uptime Hours 48428 Reset 246 248 248 6.13s S/W Watchdog (r) 3 Hrs 11 Mins 54 Secs Uptime Hours 48431 Reset 247 249 249 6.13s S/W Watchdog (r) 20 Hrs 52 Mins 50 Secs Uptime Hours 48451 Reset 248 250 250 6.13s S/W Watchdog (r) 3 Hrs 5 Mins 37 Secs Uptime Hours 48454 Reset 249 251 251 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 13 Secs Uptime Hours 48455 Reset 250 Assertions : Id S/W Rel File Name Line 129 6.10s lazy_ack.c 890 137 6.10s poller.cc 1104 138 6.10s poller.cc 1104 152 6.10s lazy_ack.c 890 158 6.10s lazy_ack.c 890 159 6.10s lazy_ack.c 890 169 6.10s lazy_ack.c 890 170 6.10s lazy_ack.c 890 173 6.10s lazy_ack.c 890 175 6.10s lazy_ack.c 890 187 6.10s lazy_ack.c 890 191 6.10s lazy_ack.c 890 199 6.10s lazy_ack.c 890 208 6.13s lazy_ack.c 890 209 6.13s lazy_ack.c 890 225 6.13s lazy_ack.c 890 Last System Error Data: ID (251) S/W Rel (6.13s) Reason (S/W Watchdog)
May 14, 2009 | 3Com SuperStack 3 4400 (3C17204-US)...
3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch Logo
499 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
