Question about Panasonic Televison & Video
When turning on the set with the power switch or the remote hear click but set does not come on. angel light is flashing.
  • 927 Answers
Good Day jspikes;
Most sets will blink when they do not turn on, but each brand flashing varies of what it means. Please give more information so we can help further. Thanks for asking, good luck Big Irish.
Posted on Jun 21, 2008
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 24, 2014 | Samsung PN58C590 TV
2 flashes wont light
SOUNDS LIKE A PRESSURE SWITCH MALFUNCTION OR A OBSTRUCTED FLUE EXHAUST. 2 FLASHES MEANS YOU ARE IN SYSTEM LOCKOUT. ATTEMPT TO START 3 TIMES THEN IN LOCKOUT MODE RIGHT? YOU WILL NEED TO TURN OFF AT T-STAT OR BREAKER TO RE-SET UNIT, OR WAIT 60 MINUTES & IT WILL DO IT AUTOMATICALLY. WHEN IT CALLS FOR HEAT THE DRAFT INDUCER MOTOR WILL COME ON, THIS WILL CREATE A VACCUM THAT OPENS THE PRESSURE SWITCH PROVING DRAFT INDUCER IS VENTING, THE VACCUM CREATED CAUSES THE PRESSURE SWITCH TO OPEN PROVIDING POWER TO THE IGNITION CONTROL. THIS IS WHERE YOUR PROBLEM IS ACCORDING TO YOUR DISCRIPTION. TRY TO DISCONNECT VACCUM LINE FROM DRAFT INDUCER MOTOR & SUCK ON IT WHILE LISTENING FOR A CLICKING SOUND AT PRESSURE SWITCH. IF YOU DON\'T HEAR THE CLICKING SOUND WHEN YOU DO THIS, THEN YOU NEED TO REPLACE THE PRESSURE SWITCH. IF YOU DO HEAR THE CLICKING SOUND THE PROBLEM IS WITH AN OBSTRUCTION IN THE FLUE VENTING. THIS IS SOMETIMES CAUSED BY DEBRIS GETTING LODGED IN THE PORT AT INDUCER MOTOR WHERE THE VACCUM LINE FROM PRESSURE SWITCH IS CONNECTED. TRY TO CLEAR OBSTRUCTION WITH COMPRESSED AIR OR A WIRE HANGER. THIS SHOULD FIX YOUR PROBLEM. GOOD LUCK. HOPE THIS WAS HELPFUL.
Dec 24, 2012 | Mr. Heater MHU45NG
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Jul 12, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
After about 1 hour the picture begins to flash and set powers off
There's a possibility your power supply isn't working properly, if it was your ballast the one causing it to turn off, you would hear a clicking sound, and i doubt it's your lamp since you do get an image, i recommend you go todiscountdashmerchantdotcom so you can get a detailed troubleshoot this way you can make a decision on which part you do need to fix this situation
Jul 01, 2009 | Panasonic Televison & Video
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Open Questions:
Televison & Video Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
