Amp will not turn on [fuse okay] - Audio Players & Recorders
MY AMP WILL TURN ON BUT MAKES A BIG SQUELCH NOISE WHEN IS TURNED ON
Posted on Jan 10, 2010
Is there an ignition fuse for the cub cadet ltx 1050
There normally only one fuse is 12 or 20 amp for all power. The only exception is the main power for the starter which is un fused.
If you getting anything worjing when the ignition is turn to the on position then fuse is okay.
Mar 22, 2015 | Cub Cadet Garden
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
I have a 2004 Mitsubishi Endeavor I heard a loud pop above the glove box and the stereo turns on but there is no sound
Power amp IC problem.
The loud pop came from the audio power amp in the stereo unit. It was cause by a shorted wire going to the speakers.
Check first the amplifier fuse if it still okay, located at the stereo harness, you have to remove the stereo unit to check on it. If that fuse is still okay, the problem is much worst you have to bring the stereo to any electronic tech shop to have them replace the audio IC( Integrated Circuit ), soldering is needed to replace it.
Hope Fixya helps you out!
Aug 28, 2011 | 2004 Mitsubishi Endeavor
Lights will not work
MAKE SURE BATTERY VOLTAGE IS 12.5 VOLTS.IF BATTERY OKAY.IF BATTERY CABLES VERY OLD YOU COULD HAVE BAD GROUND BATTERY CABLE.IF BATTERY CABLES GOOD.CHECK HEADLIGHT FUSE SHOULD BE 25 AMP FUSE.IF FUSE OKAY.YOU HAVE FAULTY HEADLIGHT SWITCH OR FAULTY DIMMER SWITCH.
Mar 20, 2011 | 1992 Jeep Wrangler
I have a 2006 GMC Envoy and the problem that i have is that all the signal lights stopped working including the hazard lights i checked all the fuses and all are find. What could it be? If somebody can...
{: ) If the IGN E fuse and the HAZARD fuse at the underhood fuseblock is okay, and the signal lamps wont light or flash at all, and assuming the wirings & connectors are also okay, it could be your turn signal multifunction switch or your turn signal hazard flasher module that is faulty.
Feb 26, 2011 | 2006 GMC Envoy
1996 Dodge 3500 I Have No Turn Signals Or Hazard Lights If I Press The Brakes & Try The Signal It Comes On the Opposite Side But Want Blink
Check the 20 amp fuse if it's blown. This fuse is located in the power distribution box on the left hand side by the firewall. If the fuse is okay more than likely your multifunction switch needs to be replaced.
Jul 12, 2009 | 1996 Dodge Ram 3500 Club Cab
Replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
Is the fuse in the plug okay?
If the fuses are not blowing when you are turning the tv on, this suggests that the PSU primary side is okay.
Since you have opened the TV up, I would suggest probing around with a multimeter however I do not want to let you harm yourself or the TV.
Look for any:
http://en.wikipedia.org/wiki/Capacitor_plague
on the power supply
Aug 13, 2008 | Prima CV1311 TV
Cold weather blown fuse
You might want to try better quality fuses, or allow the amp to warm up a bit before you start bumping down the street make old ladies angry.
Jun 01, 2007 | Rockford Fosgate Punch 700S Car Audio...
 Grubhead
Grubhead
