No sound from my computer speakers. Media player says there is a problem with my sound device. ???
  • cjcruzan Jun 22, 2008
    Had the CD's, did just that. Enjoying my music. Thanks ya'll.
    President:
  • 1,314 Answers
You need to reinstall your sound driver. If you don't have the original CDs, go to your computer's website and download it by model. If it's not a name brand, go to the motherboard company's website and download it from there.
Posted on Jun 21, 2008
I have a set of Saitek A250 Wireless speakers and a set of Logitech speakers. I can't get iTunes to play on the Saitek speakers, but Windows Media Player and normal Windows sounds do without issue....
click start control panel sounds and audio then select audio make sure the default player is the media you want to use as your default sounds also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
May 22, 2011 | Saitek A-250 Computer Speakers
Hey my sound will not work on my media players? any help?
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | Cybernet Systems CA-3080, CYBER ACOUSTICS...
Woofer 4650 carcit digram
Establishing computer speakers includes networking to the devices from where media from be derived either as computers stereos of media players. First, the speakers require connection established between each component sound producing device that has an impression in generation capacity. Second, the speaker device have a box usually the woofer as central area with power cuicuit features. Connectable cables are power cuicuit related expected to extend from the woofer to the power outlet. Also, the woofer board would require as last connectivity, the cable attacchment to the devices that produce sound either as stereo music medis players, digital media displayers among mentionable media devices.
Feb 14, 2011 | Creative Labs MegaWorks THX 550 Computer...
My speaker system was humming loudy and now only makes a loud static noise.
you might have to uninstall then restart your computer then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | Altec Lansing AVS 500 Computer Speakers
Poor sound quality
Many laptops have very small tinny sounding speakers built into them. If you wish to get better sound you can hook it up to a set of external speakers through the headphone port (or line out if it has it). You may also be able to get a set of USB powered external laptop speakers for your laptop.
You can check that there isn't dirt covering or stuck in the speaker grill, and that you don't have the volume too loud that it's overpowering the speakers.
Hope this helps, and thanks for using FixYa!
Jan 20, 2011 | Computers & Internet
Audio problem
possible conditions of malfunctioning audio on PC desktop
Hardware conditions
1. The computer speakers are malfunct
a. The computer speakers have a blowout
b. The computer speaker are misconnections to the computer
software condition
1. The computer has missing audio programs
a. A restoration of the computer program systems requires peripheral system function adjustments or updates
Repairing computer hardware malfunctions
1. check for misconnections between computer to speakers. The speaker connectors should be inserted in the audio output posts on the computer.
2. A restored computer to new version of operating system would have obmitted the patch codes to a speaker that was disconnected during the process.
Repairing computer software malfunctions
1. Open up a multimedia player on the programs menu, examples windows media player, real one player, jukebox players, apple players.
a. Select a soud file from the player list category to be played.
b. A functional media player would display a sound file represented with a status bar about the sequence of motion generate.
c. The sound at which point requires out devices like speakers attachments to the computer ports to be heard.
4. A connected computer speakers should display sounds of the clips being played on two conditions
a. First, the sould loudness has not been muted to a shut down
b. Second, the sould loudeness has not been reduced least being heard
Important notes
1. hardwares required to generate sound from a computer, an intergrated speaker on the monitor or an external speaker device connected to the system tower unit,
2. Software programs on the system unit are available, examples real media players
3.A system restore to computer defaults alters the conditions of connectable devices like speakers requiring adjustments. Note, a missing program contributing towards achieving sound soon after a media player has been launched, a sound file selected, would display a message prompt requiring UPDATES, UPGRADES or MISSING DRIVER CODES
contact expert technical support
Dec 20, 2010 | Computers & Internet
No sound device message when playing music in windows media player. no sound in any application even in opening and closing my computer
First Check you have Properly inserted Speaker Jack in right Jack in your computer sound panel. and also make sure that speakers are working perfectly.
if above connection are Ok then Try to play Other Music files in other Music Player like WinAmp, Cyberlink etc... If sound is comming then Install newer version of Windows media Player. other wise there is
Mar 22, 2010 | Microsoft Windows XP Home Edition
Speakers are not working
sounds like your audio wizard has made google your default player. Try running the wizard with your media player and make the player the default device for your system.
May 06, 2009 | Logitech X-530 Computer Speakers
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
