Question about Dryers
Maytag dryer mod# PYE2200AYW ser# 10077460WD This dryer has been working very good. now it just stoped heating. still runs but no heat. the element checks out fine. i'm lost on whats next. can you help? Ted.
  • 246 Answers
Most of the time not heating is cause by a lack of power in the circuit. Most of these problems cannot be checked visually. First thing you can do is try turning off your circuit breaker at the circuit breaker box (should be a 30A double breaker) For most everything else, you will need a volt meter, continuity tester, multi-meter, etc to get very far. If you have a friend with one or you can even pick up cheap one's at electronic and hardware stores. THE FIRST THING TO DO IS UNPLUG YOUR DRYER. The element is not the only thing that can go bad on one of these dryers and cause it not to heat. On the lower right hand side of your dryer (where you checked your element) there are other wires that plug into connecters on the side of it. One set will go to your thermistat, one set is for you high limit fuse and one goes to the element itself. Check for continuity across each of these. If one reads open, replace it. Also if you come back slightly towards the front of the machine and a bit to the left, you will see a white piece of plastic with two blue wires going into it. This is your thermal fuse. Check for continuity on it as well. If these are still testing ok, the last check is to eliminate a bad wall outlet or power cord. YOU WILL BE DEALING WITH POTENTIALLY LEATHAL VOLTAGES ON THIS TEST, DO NOT TOUCH ANYTHING WITH YOUR BARE FINGERS. Remove the panel that covers abover where the cord goes into your dryer. You should see 3 brass colored screws. Set your voltmeter to VAC. Plug the dryer back in. Using ONLY your test leads, touch them to the two farthest apart screws. You should see a reading of 240 VAC. Measuring between the middle and either of the ouside screws you should see 120 VAC. If you still are having problems, drop me a message back.
Posted on Jun 21, 2008
Hi, I have a Roper electric dryer (mod RED4340SQ1, SER MU2130244, Type 0433-ELE-2406026) that heats up when drying, yet does not heat up enough to dry the clothing. All other functions seem to work. ...
repairs should be performed by an authorized repair person. the heating element coil may be broken and grounding itself the the module housing. if so replace the heating element.
Jun 02, 2017 | Roper REX4634KQ Electric Dryer
Mod. MDE9700AZW good mor. dryer runs ,but no heat. no manuel, thinking it's the heating element or fuse. like to know there on the washer it's locations. thanks!
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 29, 2011 | Maytag Dryers
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Maytag Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Dryer shuts off before cycle ends
You really need a multimeter to troubleshoot the problem. The melted cord indicates a bad connection. The receptacle and plug connection could be the problem.
Aug 03, 2009 | Maytag Dryers
Maytag Dryer PYE2200AYW runs for a few minutes and shuts off. Have replaced heating element (as it was not heating), fuse and coincidentally power cord b/c it had melted a little due to no strain relief....
You need to check the high limit thermostat. If the heating element and thermal fuse are good, that would be the next thing that I would look at. It is attached to the ductwork with two screws and is usually a small, round, black device mounted on a flat metal base. I am attaching a photo of a thermal fuse and high limit thermostat to help you identify the component. Hope this helped and best wishes.
Aug 02, 2009 | Dryers
Dryer will not heat. Mod: 11066652500 Ser: MS2302035
If your dryer is electric, it's most likely a thermal cut-off or the heating element. if it's gas, it's probably the thermal fuse. i do lots of these each week. 90% of the time it's what i just explained. good luck :)
Jul 03, 2009 | Kenmore Dryers
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Maytag Performa Electric Dryer, model # PYE2200AYW.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Oct 18, 2008 | Dryers
Dryer wont heat
if you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Apr 04, 2008 | Dryers
Dryers Logo
133 people viewed this question
Top Dryers Experts
