Question about Samsung HCN5527W 55" Rear Projection Television
Auto focus I changed the convergence board, now the perfect focus will only go to 37%. At least the set is watchable now, but is there somehow I can fix this problem? The words are still fuzzy. Thanks, Blenda
  • blendagour Jun 24, 2008
    I don't have the money to hire a service tech, but I used the Mute 183 to get into the service mode and fix the convergence lines. The perfect focus will now get to 83%, but will not save the data. Our picture is fine at this point, so I guess I will leave well enough alone.
  • blendagour Jun 25, 2008
    It does stop on the blue and gets very cloudy.
    Sergeant:
  • 395 Answers
You will need a service tech to alien the convergence in the service mode then perform the perfect focus in the service mode to lock this setting in memory.
Posted on Jun 21, 2008
  • Robert Johnson Jun 25, 2008
    does it stop during the blue alienment? I have found that the blue gun often has the fluid get cloudy and the sensors can't find the blue. this can play havick with convergance amps.
    the fluid in the blue gun needs to be replaced, and the crt face cleaned. after that is done then it should recognize the blue lines on the sensors. the fluid is ethylene glycol and should be handled with care and disposed of according to local law. I've done a number of these sets, all of them have this very problem. fluid replacement should be done in a clean room and ware protective clothing and latex gloves.
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
Flash focus will not finish
replace the small convergence board on the left bottom board within the metal case.
Jun 21, 2008 | Samsung PCJ522R 52" Rear Projection...
PCN5425R
Sounds like the digital convergence controls is possibly the item giving you the problem, if you have already changed the convergence board. You can get a used digital convergence board at the following link, just leave them a email and state your model number and what your needing.
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung 42" rear projection HD tv issue
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Mar 05, 2008 | Samsung HCM4215W 42" Rear Projection...
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Perfect Focus
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
