Question about NEC Computers & Internet
The color balance on my LCD monitor is hosed. How do I restore the white balance using rgb?
    Scholar:
  • 141 Answers
Hi slk,
im not sure of the exact values for your rgb that would restore you white balance but you can install Adobe Gamma. Hope it helps.
Posted on Jun 21, 2008
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
I am not getting the correct colors from my SLR camera. Is this due to my computer monitor?
Yes, the monitor need to be calibrated using an optical attachment (looks like hockey puck) that is placed on the screen using software, but the monitor must support automate software calibration. You can google for LCD monitor color/white balance calibration tools.
Apr 07, 2010 | Balance CM2019 19" LCD Monitor
My web pages are to bright/ white.how do I fix this I would love to be able to see all the images. The background is white which blends with any light colors.
You can try to reset the monitor settings. Press the Menu button on the monitor and select and select Auto image adjust or reset option. This should bring back the colors or you can manually adjust the RGB (Red Green Blue) color bar from the menu.
Hope you find this information helpful.
Thank you for choosing Fixya
Dec 19, 2009 | Acer AL1706AB LCD Monitor
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Oct 26, 2009 | LG L1920P 19" LCD Monitor
Monitor
Press the menu button on your monitor, then use the controls on the monitor to select something like color balance and turn up the red.
Jul 28, 2009 | Gateway FPD1975W 19" LCD Monitor
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Balance status of my A/C
I have a balance LCD 17" monitor when I turn it on i get a message of RGB NO INPUT SIGNAL!
Dec 11, 2007 | Balance CM2017 17" Monitor
Computers & Internet Logo
51 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
