Sylvania G-Netbook Logo
Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get online wired or wireless. I have configured the wireless and it says I am connected with excellent strength, however, I cannot get on line. When I get the error, the corner icon says local intranet instead of internet. I don't know how to change that.
Narseman
Level 3:
President:
  • Master 1,088 Answers
  • Posted on Nov 19, 2010
Narseman
Master
Level 3:
President:
Answers
1088
Questions
Helped
311427
Points
3782
Go through your Network Connections, and use the Wizard to make a new connection. Follow the wizard to connect to the " Internet."
Other thing to check is, On the router, do you have the WAN connected to your internet service.?
Otherwise, your connection to the router will be great, but the router will have no service to access.
DIR-815 Signal strength excellent but no internet
Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
1helpful
Computer says,"connected to network signal strength excellent", but I cannot connect to internet
Can you connect to the Internet using the LAN cable?
Have you configured the wireless card in your laptop with the router's wireless settings?
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Installed Trendnet wireless adapter. Connection shows excellent but can't browse internet
The "excellent" is the signal-strength between your wireless adapter
and your wireless router.
You still need to select the SSID ("network name") that you configured into the router, and enter the password for your network, before you can connect to the Internet.
Compare it to having a brand-new mobile telephone. Until you dial a friend's number, and the friend answers, all you have is an "excellent" telephone.
Power went out and now my router is working fine but the wireless PCs cannot connect. "Limited or no connectivity" even though signal strength is excellent. Tried cycling the router. no luck.
Access the router's setup page/configuration page and change the channel of your wirelessrouter to 1, 3 or 11. Make sure you know if the wireless encryption is ON and get the key.
I can connect my laptop using the ethernet cable. My daughters laptop works with the wireless, but I cannot connect my laptop via wireless. My laptop indicates that it has excellent signal strength but I...
make sure you putting the wep key proper and use the same wireless key which is configure in to your daughter laptop. and also try tio ping the wireless ip address to make sure the connection is proper.
Have a nice day and do not forget to rate please...!
2answers
1helpful
Can't connect to the internet
Try to disable any firewall you have on your computer like windows firewall or any third party firewalls like zone alarm, norton and mcaffe
I can not connect my laptop to my linksys wireless-b router......
hi! Welcome to fixya!
You need to turn off first or disconnect LAN connection which is the cable connection before you can use the wireless connection. After that go control panel you need to setup internet connection and be sure to configure the IP address to automatic which the DHCP mode configuration then restart. That's it. Have nice day!
Sympatico
  1. Start your network in this order:
    1. Turn the modem power off.
    2. Turn the router power off.
    3. Turn the modem power back on. Wait two minutes until the lights are stable.
    4. Turn the router power back on. Wait one minute until the lights are stable.
    5. Turn the computer power back on.
  2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to http://kbserver.netgear.com.
  3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  4. Click OK. This logs you into the router
  5. Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
  6. The Setup Wizard will detect the type of Internet connection. DSL connections which require a login to connect to the internet will be detected as PPPoE. Click Next
  7. Configure your router with the username and password provided by your ISP and click Apply.
  8. The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
  9. Verify you have a valid IP address (not-blank / 0.0.0.0) on the Internet Port assigned by your ISP
  10. check if you are able to go online wired..
  11. to setup wireless
  12. Click Wireless Settings under Setup menu.
  13. Under Security Options, Select WEP (Wired Equivalent Privacy)
  14. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  15. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
  16. then check in your w/ls laptop, you would find your w/ls n/w name , try connect to it, enter your key , you would get connected
Top Sylvania Computers & Internet Experts
Paul Bade
ADMIN Eric
ADMIN Eric
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
