Question about Sony KV-35S42 35" TV
Can you anser my Questions(Brad)
Posted by Juvan on Sep 02, 2007 Report abuse
tv is set to stereo (not mono or sap.) in the audio settings the speakers are set to 'on'. sound WAS working just fine but i hit a button on the remote and now i hear nothing. i have since tried hitting all the buttons in multiple order and combinations and still nothing. any suggestions?
Post Solution Work Queue --> Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Bradlo0600, posted on Jun 07, 2008 I have a problem that just started with the sound on my Sony KV-35S42. For some reason, the sound comming oout is real low even when you turn the control all the way up. I looked through the menu and under the audio area, there is a values set called "Variable: Audio Out".
I am wondering two things.
1. Can I bypass the sound somehow by hooking up a home theatre system to the sound jax ports to play sound out of my DVD or out of my verizon cable box.
2. Do you think this would be worth a repair. The local shop says it's $90 just to pull the box.
06/07/08
Bradlo0600@verizon.net
    New Friend:
  • 76 Answers
First we have to check whether the problem arrives from Source or audio output section. If you have Amplifier connect TV audio out to Amp. in. Now check difference as you said. Now the complaint continuous failure is from audio source orelse the problem in audio output section. This would be a worth to repair. Before to proceed the above things go through the audio menu and check the sound system like BG,I,DK depends upon your region. I think my information is littlebit useful to you.
Posted on Jun 24, 2008
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
My truflat is speaking spanish on some channels and some channels showing picture and no sound . and the when i turn stereo,mono,and sap pops up.
you have teh audio set in SAP mode. Some nits have the audio mode button on the remote. Otherwise go into the audio setup menu and choose MTS(stereo) or mono.
Apr 28, 2010 | Televison & Video
I have no volume on channels 2 and 7. All other
Your SAP audio function is on. Look on your remote or in the TV menu for SAP or MTS. There are 3 settings, Mono, Stereo, and SAP... set it to Stereo. I hope this was helpful, best wishes.
Mar 28, 2010 | Toshiba 32A33 32" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Toshiba TV sound vanished
It is possible that the TV set has an SAP (secondary audio program) setting that has been turned on. To check this go in the the menu, find audio settings, usually the correct setting for this is Stereo, other setting may include Mono, Surr-Stereo, etc.
Feb 05, 2010 | Toshiba 36A40 36" TV
No sound on channels that have SAP instead of Stereo
You can access the menus using the buttons on the set. Go to audio menu, you'll find a setting that says listen to and have choices of mono stereo or sap, choose stereo.
Oct 08, 2009 | Mitsubishi Televison & Video
Magnavox tv
In menu page Audio>Stereo>Mono>SAP.......Audio is sometimes called MTS........................T.
Jan 24, 2008 | Philips Magnavox 27MS343S 27" TV
No audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Sep 03, 2006 | Sharp 25R-M100 25" TV
Sony KV-35S42 35" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
