Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Frigidaire ice cubes coming with square edges...
Purchased a GE side by side refrigerator and the ice cubes have sharp edges..I have had the repairmen out several times and they indicate the ice maker is working as it should. I am afraid someone will cut there lip on the ice cube. Anyone had the same problem or know a fix ??
  • 3 Answers
Get a life, sharp ice cubes? The edges melt and the problem goes away.
Posted on Jun 21, 2008
The ice comes down cube but it will crush in the glass
Good Afternoon Friend,
I understand that the ice is dispensing as cubed, in your Frigidaire refrigerator, model# GLHS269ZDB, but once it hits the glass it breaks apart and crushes. Please remove the
ice bucket. Against the back freezer wall, you will see a square opening with either a white or clear switch that can be adjusted up to down. If you have a blow dryer, blow dry the square opening for about 7 min's. Once done, adjust the switch. It will either move freely or will remain in its opposite position. Replace the ice bucket. This should allow cubed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jul 01, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
We emptied ice bucket to fill cooler. Now all we get is crushed ice and not cubes. I can switch buttons from crushed to cubes but still get crushed. Did we do something wrong when I pulled out ice bucket...
There is a metal rod under the ice bucket. This rod sticks out from the back of the bucket. Where it inserts into the ice shelf, you will see a small square hole. This is what changes it from crushed to cubed. It is an actuator that moves the rod to allow cubes to come out. Stick a screwdriver into the square hole and move the actuator up and down. Then reinsert the ice-bucket and that should fix the problem. Hope this helps.
Mar 24, 2011 | Frigidaire FRS23H5AS Side by Side...
Ice maker will not despends any ice cubed or crushed
a cube of edge "a" is cut by a plane containing two diagonally opposite edges of the cube. find the area of the section thus formed.
Jan 05, 2011 | Frigidaire FRS26R4A Side by Side...
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker will not make ice dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
Dec 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Cube dispenser does not work...
Is the ice in the bucket all frozen together as one big lump ??
Aug 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire-side by side model #GLRS267ZDW2
take the ice tray out and on the back wall of the freezer, there's a square hole with a white little bar inside push it up or down(whichever way it's not) then replace ice tray..... should work. I've done this a few times.
Dec 03, 2007 | Frigidaire Refrigerators
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
97 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
